![]() Drives: '21 Camaro Join Date: Nov 2019
I'm working on buying a '20 Camaro early next year, and I want an exhaust system that's better than stock. I don't have any experience at this level, so I need some info.
I have 1 requirement: it has to sound 'normal' at certain times (I believe that's where the 'dual-mode exhaust' comes into play.) I think that's NPP -- correct? I know that I can get a better system from the factory, but I'd like to consider after-market (I'm sure it would sound even better). Is there a consensus on a comparison of GM's upgrade and after-market? So, figuring that I'll get an after-market exhaust, how should I equip my vehicle? Should I get the dual-mode option, and standard exhaust? Or? |
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
If getting an aftermarket exhaust, there's really no reason to get the factory NPP. Just extra wasted money in my opinion. Personally I think the upgraded factory exhaust is the way to go if you already know beforehand that you want some kind of extra noise
#3 | |
Perhaps there's something I don't know about aftermarket exhaust systems -- would it add that function? |
#4 | |
![]() Drives: 2019 ZL1 / LE , 2014 CTS V Join Date: Nov 2015
If you want the modes your going to need to pick a system that lets you keep the NPP set up. Borla, Stainless Works, Magnaflow and Im sure others give you that option. Im torn right now between AWE and Stainless Works myself. The AWE system doesnt support the NPP. I love the sound of there exhaust and you cant beat there prices but, theres something that sits wrong with me about not having the NPP option since it came with the car. In regards to the Stainless, I havent been able to locate enough sound clips from there axleback to make a decsion to go that way. |
Well that's the thing. With an aftermarket exhaust (not NPP) there really is no "quiet or loud mode". Some systems are quieter than others, and of course how you drive, but that's the trade off. GM makes their own axle back exhaust for the Camaro that's actually covered under warranty. Might wanna check that out as well
#6 | |
But, can I get the skirt/facia (or whatever that bottom panel with the exhaust cutouts is called) for the dual-exit BUT with the standard exhaust? |
#7 | |
![]() Drives: Camaro Join Date: May 2018
#8 |
#9 |
![]() Drives: 2018 Chevrolet Camaro RS Join Date: Mar 2019
I highly recommend the Borla ATAK axlebacks. They come with NPP or non-NPP options, dual or quad-tipped. I swapped my diffuser to allow the quad-tipped unit and was very pleased with the increased sound and deeper tone.
#10 | |
Do you have the ATAK? I'm curious if they might be too loud. (I don't want a rip-roaring beast.) I'd have to hear various setups; I'd like to know how GM's upgrade sounds compared to the S type. |
#11 |
In my opinion, no, it's not loud. It's fairly loud on cold start, then quiets down. Sounds great in the car under throttle. But as to how it sounds outside, as too being TOO loud, I don't know.
#12 |
![]() Drives: camaro rs v6 2017 Join Date: Oct 2019
borla
I have the borla s type on my car- 2017 v6 and it sounds awesome, all my friends with their mustangs also love the sound of my car
#13 |
![]() Drives: 2018 2SS Camaro Join Date: Jul 2019
Here try this and see if it helps you decide...I was leaning towards the S-Type until I heard them. I ended up getting the...Atak. I absolutely love the sound!
I also found an incredible deal on the Atak exhaust system, so that helped https://m.youtube.com/watch?v=JtOlxn3M1WI |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
afe power ftw
| Tags |
| after-market exhaust, dual-mode exhaust, exhaust |
