![]() Drives: 2018 1SS 1LE Join Date: Jul 2012
MM wild or mild
I will be installing my procharger soon. I know the MM wild is the better of the two but is there any reason I can’t run the “mild” to help vent pressure?
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
I run a standard catch can with metco valve cover breather....seems to work fine.
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
Far better in every way to pull full time evacuation then allowing pressure to build and vent and leave most of the combustion byproducts in the crankcase to accelerate wear. Especially with a Centrifugal SC or turbo, and to stop 95% plus vs less than 1/2 of the substances your don't want ingested.
#4 | |
2009 Pontiac G8 GT—605rwhp, SOLD Last edited by MSU120; 11-16-2019 at 07:32 PM. |
![]() Drives: 2SS Join Date: Sep 2017
Mighty Mouse Wild top quality easy fit with procharger and does everything you need
Thank you. Do you know if the mild version will work though?
#7 |
Anyone? Will the MM mild work?
#8 |
Dyno Show Queen LOL
You can upgrade the the Mild MM can with larger fittings later and larger hoses later on if need be and change the routing just a little.. not a big deal.
#9 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I have the Mild and it will certainly work no problem however the WILD can comes with a built in 1 way check valve on one of the can connections and the MILD does not. You may need a couple 1 way check valves so that when you go into boost it blocks any from getting into the can.
