Old 11-11-2019, 06:14 PM   #1
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Tuner said not to touch front seal???
So in preparation of the Maggie install I grabbed everything I wanted. MM Wild catch can, Rotofab intake, 160 thermostat, TR7 plugs, MSD wires, LS3 cam seal, etc... Tuner said my seal looks perfect and said "with the system done properly I shouldn't have crankcase pressure". He said the CC will take care of it. They build plenty of 1000RWHP cars so I am trusting their judgement. Anyone differ? Car has 8K miles
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 11-11-2019, 07:13 PM   #2
Drsagacity
Drsagacity's Avatar
Which car are you working on? Are they saying they hit 1000whp on the 2300 Maggie on the LT1?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 11-11-2019, 09:27 PM   #3
laynlo15
Drives: 2022 Lt1 A10
Teddy I put an LS3 seal in mine but I was running 16 lbs of boost without enough crank case ventilation. That call is up to you and the installer, I would recommend the change since your there with the balancer off but you are running pretty low boost so it will probably be ok.
Old 11-12-2019, 08:04 AM   #4
Slowhawk
Drives: 1999 Trans Am
When changing a balancer we install a new seal every time for piece of mind.So it forms on the new balancer. Do you have to? no
Slowhawk is offline   Reply With Quote
Old 11-12-2019, 08:04 AM   #5
L78toLT1
L78toLT1's Avatar
I went with an LS3 seal also even though I'm only running around 10psi boost. That LT1 seal was like tissue paper. Even though it may hold up at low boost, I'd swap in the LS3 seal just for peace of mind. Not to mention what a pita it is to remove the balancer on these cars in the event you do have to replace the seal.
Baby Blue
Old 11-12-2019, 09:09 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I changed mine...low boost or not the factory LT1 seal isn't very good and has been known to leak even on NA builds.
If the balance comes off then it is a good idea to change it, like Slowhawk said(This guy knows his stuff BTW!).
Old 11-12-2019, 12:08 PM   #7
teddyca
teddyca's Avatar
Thank you guys for the replies. My build is a TVS2300 with intake and exhaust. They have done quite a few of these. As for the 1000HP reference I was just referring to "other" builds. Well with that said I am going to leave it up to them.
Old 11-12-2019, 01:12 PM   #8
laynlo15
Its pretty unanimous to change it as one noted they are very flimsy compared to the LS3.
Old 11-13-2019, 07:38 AM   #9
JANNETTYRACING
JANNETTYRACING's Avatar
For the ten minutes it takes to change it, it's not worth the mess it makes if it does fail.
It is a low drag low tension seal so if you look at it wrong it rolls over.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 11-13-2019, 08:55 AM   #10
KingLT1
KingLT1's Avatar
Ted.
Hey now that shop builds 1000whp cars...don't argue with them!! lol
Old 11-13-2019, 02:32 PM   #11
teddyca
teddyca's Avatar
No intent on arguing. If it fails car will go right back.
Old 11-13-2019, 03:04 PM   #12
Juiced1
Drives: 2012 2SS CAMARO 45th
These LT motors seem to make a ton of crank case pressure under boost. We had oil come out on a few already (bolt on LT4 cars). The LS3 seal upgrade is a good idea if you're already in there.
Juiced1 is offline   Reply With Quote
Old 11-13-2019, 06:20 PM   #13
teddyca
teddyca's Avatar
Unfortunately this is a very debatable topic. I had someone tell me they simply upgrade the PVC lines to 5/8" and had great results, some say no catch can, others say use a catch can, and then the whole seal controversy. I have ordered everything I feel was what is right. They didnt want to touch the seal so I am letting it go. If I post about "oil leaks" you guys can tell me "told you so" HAHA
Old 11-13-2019, 07:00 PM   #14
Drsagacity
Drsagacity's Avatar
Ha! It’s not “if” but “when” my man. Regardless, can’t wait to see your results. At the same time, your initial build will be between 530-575whp depending on you pulley. At that level, I have no doubt you will be fine. If you should decide to turn up the boost, you will be making other changes anyway and can change the seal then.
TBD performance
