Old 11-11-2019, 03:41 PM   #1
Drew145022
Drives: 2017 Camaro 2SS Vert
Action required:Shift to park
Car is in park but I’m getting the “action required: shift to park” It doesn’t happen all the time but when it does i turn on and off the car while moving from drive to park over and over again till it goes away. I have seen the post that says it could have something to do with a low key fob battery so I replaced it but it still happens. Any help would be great.
Drew145022 is offline   Reply With Quote
Old 11-12-2019, 12:28 PM   #2
numbersnerd
Drives: NGM 2018 2SS Convertible
There seems to be a known problem with switches inside the shifter. The usual fix is to replace the entire shifter assembly. When I had the same message the dealer had 5 Camaros waiting on the assembly and they had no ETA. That was a while ago and well before the strike, so no idea what the supply is like now.
I did some digging and some people clear it up with a shot of WD-40 to the micro switch inside the assembly, others just jiggle it until it goes away.
In my case the message was a symptom of another problem, so I didn't need to have it replaced.
numbersnerd is offline   Reply With Quote
Old 11-18-2019, 03:26 PM   #3
Shanne69
Drives: Drive 2016 2LT V6
Happened to me... changed the assembly. It’s not your fob.
2016 - 2LT/V6
Shanne69 is offline   Reply With Quote
Old 09-14-2020, 06:26 AM   #4
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Bringing back from the dead. Would the shifter replacement be covered under the powertrain warranty?
dmcmahan60 is offline   Reply With Quote
Old 09-14-2020, 07:01 AM   #5
Hops
Hops's Avatar
Drives: 2019 1ss 1le, blue wrap
The exact same behavior the OP is describing, is happening on our 2019 Traverse. When it starting a couple months ago, it didn't happen very often. Now it happens every time the car is turned off. We're taking in it.
Hops is offline   Reply With Quote
Old 09-14-2020, 06:43 PM   #6
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Ditto...replaced shifter assembly. My car was already past warranty, so out of pocket.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 09-25-2020, 06:31 PM   #7
rshelar
rshelar's Avatar
Drives: 2017 1SS auto vert Nightfall Gray
Mine is in Chevy dealer now. Told assembly replace and not covered.
I'm still just under 60k so I'm going to Customer Care.
Anyone have this covered?
rshelar is offline   Reply With Quote
Old 09-25-2020, 09:35 PM   #8
Hops
Hops's Avatar
Actually i'm not sure our Traverse shifter problem is related https://gm-techlink.com/?p=12155
We were under warranty on our Traverse. This seems to happen to a lot of gm vehicles. We had to go back twice. The first fixed sort of worked (it was a wiring harness jumper... it think). We took it back again and they replaced the whole shifter.....
Old 10-24-2020, 11:29 AM   #9
bravomayor
Drives: chavrolet camaro
I have the same problem on my 2017 Camaro RS with the 'shift to park' any idea how to fix this because dealer try to charge me 700 to replace the shifter, help please!!!
bravomayor is offline   Reply With Quote
