O2 Sensor replacement
Hey all,
My upstream O2 sensor on the driver side is shot and I am attempting to replace it myself. (Not a mechanic at all, pretty new to doing self maintenance as well.) I was able to get the actual sensor off and out of the cat, but i'm struggling with getting the wiring harness disconnected. I pulled up the white tab, and that's about as far as I've gotten with it. I don't have much room to look around and see if i'm missing something. Is there another piece holding it in that i'm missing? Or is it just the white tab and that its stuck? Thank you! |
Figured id add a pic just incase it helps at all
2016 Camaro SS w/ A8
Update: incase anyone gets in my situation. I pushed the white tab out, and then with a tiny flathead screwdriver, i pushed the middle of the white pin inwards and that released the o2 sensor from the wiring harness. Not sure thats the proper way to do it, but it worked for me.
(Sorry for thread bumping)
#4 | |
![]() Drives: '23 LT1 Join Date: Apr 2023
#5 | |
I assume you pulled a code which pointed you to this sensor? |
#6 | |
I would quantify my current level of torque (hand torqued) as quite tight without giving it everything I had. (I tried that, it just kept turning!) |
#7 | |
The catback may have been corroded. There is a tool called a thread chaser which is good for that situation. Better than a tap as it pushes distorted metal to "rebuild" the threads. They definitely make thread chasers in spark plug and oxygen sensor sizes, as those are common locations this can be useful. |
#8 | |
| Tags |
| o2 sensor, replacement, stuck, wiring harness |
