Old 11-10-2019, 10:01 PM   #1
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Soaps that DO NOT affect coating/sealant/ wax behavior.
There are many names, and are wanted for different (but really the same)things. Let's make a list!
Car Shampoo / Soaps that DO NOT have gloss enhancers
Car Shampoo / Soaps that ONLY clean
Car Shampoo / Soaps that are good for coatings
Car Shampoo / Soaps that don't change the hydrophobic behavior
Car Shampoo / Soaps that leave NOTHING behind
Such as
Soap------ wash bucket dilution []price per gallon of soap
CarPro Reset ----- 2.5oz per 5 gal []$85 a gallon~
Geyon Bathe ----- 1.2 oz per 5 gal [] $100 a gallon~
Meguiar's Hyper-Wash ----1.4 oz per 5 gal []$28 a gallon
NanoSkin Hyper Suds ----- .8oz per 5 gal []$35 a gallon
Adams Car Shampoo ----- 2oz per 5 gal []$39 a gallon
Possibly
Chemical Guys Citrus Wash Clear* ---- 1oz per 5 gal [] $25 a gallon
*(Chemical guys....one page says its a clean rinsing basic wash, another page says it enhances gloss. The label on the smaller bottles say it enhances gloss, the label on the gallon does not. So the usual chemical guys issue of great product with ham fisted marketing)
I have reset. Its fantastic in everything but price. Soap with less in it should cost less, right? The nanoskin is supposed to have very high lubrication also, but for $50 less a gallon.
I have citrus clear, not a lot of lubrication at its normal dilution.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 11-10-2019, 10:08 PM   #2
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I ALWAYS use RESET, I don't trust anything else, that said, LOL
I just tried "turtle wax ICE snow foam.!!!
I was impressed, clean rinse for sure. I might now do Reset every other wash.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 11-10-2019, 10:18 PM   #3
SnakeEyeSS
SnakeEyeSS's Avatar
I just got another reply from nanoskin(two on a sunday night, wow!)
It said if all you want is to clean and leave nothing behind, hyper suds is what you want.
Hyper Suds dilution ratio is .8 oz per 5 gallons. Cost $35 a Gallon
Reset is about 2.5 oz per 5 gallons. Cost $85 Gallon
Apex detail shampoo reviews said Nano Skin Hyper Suds was the most lubricating shampoo he tried (until he used Reset.)He thought it was so concentrated it was hard to dial in for different uses(comments on one of his two videos on it.)
For the huge price difference I think it it would be the great normal use. Then go to reset for really nasty, grimy washes for extra lubrication. I'm ordering a gallon now, will report back once I use it.
Old 11-11-2019, 04:24 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I've used Adams and Reset on my PPF/Gtechniq coated Z.
Both clean the car. Probably just my perception, but Adams seems to do a slightly better job removing grease & fingerprints, seems easier to rinse off and had lower haze than Reset.
Old 11-11-2019, 05:58 AM   #5
Burly
Burly's Avatar
I use this combination of 2oz CarPro Reset in foam cannon and 4oz Adam Car Shampoo in bucket. Tried a lot of other soaps but I’ve been using this combination on three cars all year. Maybe overkill and expensive but it works.
Burly is offline   Reply With Quote
Old 11-11-2019, 08:50 AM   #6
harner
harner's Avatar
Drives: 2018 ZL1 A10
It may not be the most efficient, but I use Greenway's Car Shampoo. Full disclosure, I use a "splash" of shampoo because I don't have time to measure for every wash bucket. I also increase froth/foam with my pressure washer. It foams great and you can pick any color/fragrance you want when you buy which is cool.
They recommend 256:1 ratio, or 1-2oz per gallon.
https://greenwayscc.com/collections/...ys-car-shampoo
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 11-11-2019, 02:54 PM   #7
SnakeEyeSS
SnakeEyeSS's Avatar
These work great, dispense 1oz per pump, fit a lot of the soap containers.
Bar5F 2 Piece Gallon Pump Dispenser, Heavy Duty https://www.amazon.com/dp/B01GOXFCLI..._6WBYDbVEJQVG4
Old 11-11-2019, 10:49 PM   #8
harner
harner's Avatar
Thank you, sir. Going to try these.
Also, I buy Greenways wholesale at about $18/gal. If you choose to list a price, I'd go with their retail cost which is closer to Hyper Wash.
@SurefireDetail
1987 IROC
2006 Silverado
