TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
gas over flow at fill up
This has happened to me twice at 2 different pumps. I put the gas nozzle on automatic, so I don't have to hold it, when the tank is full it does not cut off in time and slightly overfills and spills on the paint.
Anyone getting gas overflowing out of the tank at fill up?
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Never happened to me on any of my vehicles.
You came across 2 bad pump nozzles. Just remember which ones not to use. |
#3 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
It happened a few times, never put the handle on 3 clicks, place it on the 1st notch and once you get over half a tank, take your hand and pump the nozzle ( LOL) slowly. You will be able to fill up with no problem.
TEXIT
New to GM
Drives: 17 ZL1 91 LX 5.0 Join Date: Jun 2019
It's happened to me twice recently. The last being after I washed it and was literally filling it up to park for the season! I had to boogy home and rewash that area in freezing weather I was pissed. Different stations so I dunno...
#7 |
TEXIT
Strange it happened at 2 different pumps at a brand new Shell station...
The first time I thought the pump malfunctioned. The second time on a different pump I thought it's the car. |
#8 |
![]() Drives: 2018 ZL1 A10 Join Date: Sep 2014
I don't have an issue with pumps in my area, but I am deathly afraid of overfilling thanks to my last car ('11 CTS-V) that verified once the pump kicks off - it's full. I live by that mantra in the ZL1 now as well. Hopefully it stays that way. Mainly using Sheetz pumps.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
#9 |
![]() ![]() Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I never had this issue, with any of the last 4 camaros I have had. I definitely dont try to top them off either. When the pump kicks off, I am done pumping.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
#10 |
![]() ![]() Drives: 18 zl1 Join Date: Aug 2017
mine did this on my 17 ss several times, on several pumps, at several stations.
It never clicked, I never "added more fuel" it was straight on the first pull to spewing out and down the fender. I learned to make sure the nozzle is in all the way, and I hold up (pointing the nozzle down more) and it never did it again. you do, however, get some false clicks on the faster pumping nozzles. |
#11 |
I haven’t experienced this with either my current 6th Gen, or my previous 2017... I always put the pump handle on the fastest auto setting, and once she clicks off I hang it up.
I have noticed that some stations pump with more pressure than others. To me it seems like the pumps that take longer to fill my tank are the ones that have a tendency to “overfill”.
#12 |
![]() Drives: 19 zl1 Join Date: Aug 2019
Strangely, i cant gas INTO my 19 zl1 1le. Any velocity at all and it is spraying out the damn side of the car. Any ideas?
#13 |
![]() Drives: 2018 Zl1 Join Date: Jan 2010
I had that happen as well Theseal. How much gas was in it? Usually its the fuel tank breather is clogged or is vacuumed locked. Try bouncing the car a bit when it happens.
#14 |
TEXIT
This is my 1st DI car, never had any issues before. I wonder if the high pressure fuel system is the culprit for all of these fueling issues?
