Old 11-10-2019, 12:44 PM   #1
Kaludar
Drives: 2018 SS 1LE
Skip-shift and warranty?
Does anyone know if disabling skip shift with void the factory warranty? I love this car, but the skip shift thing drives me nuts. I don't want the car trying to force me into 4th gear for "fuel economy" I already get 13mpg with how I drive, I didn't buy this thing to sip fuel!
Kaludar is offline   Reply With Quote
Old 11-10-2019, 01:31 PM   #2
2SSRedline
Drives: '18 Camaro SS Redline, '20 Bolt EV
Its unlikely anyone would know you put a skip shift eliminator on.
2SSRedline is offline   Reply With Quote
Old 11-10-2019, 04:46 PM   #3
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Or even care. In before the folks who say to gun it through school zones to avoid it, get one OP it'll be the best $14 you ever spent.
Warrior102 is offline   Reply With Quote
Old 11-10-2019, 05:09 PM   #4
cdrptrks
cdrptrks's Avatar
If you ever have a warranty issue you can easily unplug and remove the skip shift wiring harness from the car leaving no visual evidence that it was ever installed if you want but it seems unlikely they would even notice/check. It is definitely worth buying imo!
Old 11-10-2019, 06:16 PM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
Just don’t recalibrate to eliminate it. THAT will end your warranty.
Old 11-10-2019, 07:35 PM   #6
GAbobcat2ss
Drives: 2SS - Nightfall Grey 6m, npp, nav
Disabling the skip shift should not cause any warranty issues. My dealer actually installed mine for me. If anything it should reduce the wear some on the transmission not having it lug in 4th gear. Also my mileage improved a little with it disabled. It's your car you should be able to put it into 2nd gear if you want Really helps when putting around in heavy traffic.
GAbobcat2ss is offline   Reply With Quote
Old 11-10-2019, 08:20 PM   #7
Number 3
Number 3's Avatar
Still have to mention you can make a slight change to your shifting that will keep you from getting gated. Instead of pulling straight down to second, simply flip the shift lever to right in the neutral gate then back left and down to second. I’ve rarely been gated with this driving style to point a CAGS car has never been a problem.
Or spend the $10
Old 11-10-2019, 08:28 PM   #8
MrChrisLS3
Drives: 2018 1SS M6
Or spend the $10
Agree, it's not hard to drive around, and no, I don't have to blast through school zones to do it. It seems the window is so small that I rarely get caught in it. When I do, I just keep the clutch in, slide down to 4 and back up to 3, or back to 2, whichever is more appropriate. All that's required is the stick has to touch 4th to unlock it. You don't have to actually engage 4th gear.
MrChrisLS3 is offline   Reply With Quote
Old 11-10-2019, 08:38 PM   #9
hawk02
Coupe Newbie
hawk02's Avatar
Shift from first to second above 19mph and you’ll never be bothered by skip shift.
Old 11-10-2019, 09:09 PM   #10
JROC
Drives: 19 Camaro SS 1LE, 03 Ford Lightning
I bought my new SS 1LE yesterday and just ordered my first mod for it. That being a skip shift eliminator. Always do this for my cars that have skip shift on it. They're cheap, easy to install, are easily reversed back to stock if you wish, and they work. Their not noticeable. You just forget that the car has skip shift. Exactly how I want it.
JROC is offline   Reply With Quote
Old 11-11-2019, 03:48 PM   #11
VinnAY
Drives: 18 1SS/1LE
How do you get 13mpg, AND, get the skip-shift...it would seem you're giving it enough gas lol
Old 11-11-2019, 04:09 PM   #12
Kaludar
Drives: 2018 SS 1LE
Because I'm either driving to an from work in a very short commute through heavy traffic, or I'm on back roads on the weekends letting it rip. It's the commute part that is annoying me. I actually get under 11mpg sometimes, but im at 13mpg for the life of the car, which is at 6k miles lol
Old 11-11-2019, 06:16 PM   #13
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
On my third one. 97 Z28, 2002 Firehawk #0140 (my dumbass sold it), now this. Installed on the Firehawk prior to driving off Sewll lot in Dallas. Highly recommended. You will still get skip shift nanny notification on days, however.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 11-12-2019, 05:02 PM   #14
CrazyCatGuy
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE
I don't think winding out first gear a tiny bit longer is considered "gunning it". Coming from cars with 8K+ redlines, winding out first to 20mph is just par for the course for me in the SS. YMMV
CrazyCatGuy is offline   Reply With Quote
