Old 11-07-2019, 12:14 PM   #1
jorgesvlog
Drives: 2019 Chevrolet SS
Ported Heads with Stock Cam
Before everyone says go ahead and do cam all at once, that is not the route i want to go.
So my car is basically FBO. Has headers, intake, ported 95mm tb, ported msd, e85.
I want to do the ported heads and while im there replace the lifters, upgrade the pushrods and do the trunion upgrade on the rockers in an effort to try to increase the shift rpm to the 6800 area without valvetrain issues.
My question is can i upgrade the springs to something like the BTR .660 springs while keeping the stock cam or would staying with the stock springs be better. IE will the BRT springs being higher lift cause an issue with the stock cam.
Thanks
jorgesvlog is offline   Reply With Quote
Old 11-07-2019, 12:16 PM   #2
6spdhyperblue
Drives: 2SS 1LE
There are plenty of springs in between. Heavier than necessary springs rob power and introduce other trade offs, id look at a coated beehive.
Old 11-07-2019, 12:25 PM   #3
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
It'll be quieter for sure, with stock springs, why do you want to raise the rpm? with the stock cam you are out of the torque curve way before 6800 and there wont be any real gain, the real benefit would be to install a cam while you're doing all the other stuff, unless you just want to sound like a 5.bro.
ssmofo is offline   Reply With Quote
Old 11-07-2019, 01:35 PM   #4
Walt.v
Walt.v's Avatar
Drives: 19' Camaro 1LE
Upgrade your CAM!
I am as well FBO with E85... my lifters AND cam went out.
Learn from my mistake lol.
2019 SS 1LE
American Racing Headers, No cats
Airforce Intake Manifold
Roto-Fab Intake
E85 Flex-Fuel
Eibach Pro-Kit
GP Tuned
Walt.v is offline   Reply With Quote
Old 11-07-2019, 02:00 PM   #5
jorgesvlog
Bc I want to maximize the hp up top from the ported MSD and ported heads. Plus, I can do head swaps, but feel a bit more nervous about doing a cam swap. If I can do the heads and do the dod delete part on the top end, should be much easier for a shop to do a cam swap and therefore be much cheaper in labor.
Old 11-07-2019, 02:28 PM   #6
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
To be honest with you, I found the cam swap on my LS1 to be no more difficult that the head swap. Actually, the physicality required to break the head bolts free and crank them out made the Head swap on that car the more difficult thing between the two. The only additional thing you would have to do is removing a couple more front accessories and the harmonic balancer.
Jaxcam02 is offline   Reply With Quote
Old 11-07-2019, 02:35 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I don't think you can run different lifters on the stock cam. The stock cam lobes are designed for the afm lifters. So if you do a dod delete then you need to change cam.
Old 11-08-2019, 09:15 AM   #8
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Originally Posted by Walt.v View Post
Upgrade your CAM!
Thats unfortunate but there's tons of guys out there with a lot of miles on their fbo cars without issues. Dare I say messing with your internals starts effecting reliability a bit more.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 11-08-2019, 09:17 AM   #9
RobbyBeefcake87
You're probably right, but aren't just some of the lifters afm lifters, not all?
Old 11-08-2019, 02:15 PM   #10
jorgesvlog
King,
I had not thought about that. Figured i have the DOD disabled so the lifters are acting as normal, but they might not be the same. Ill look into it a little more and see what i can find.
Thanks!
Old 11-09-2019, 12:42 AM   #11
Tim M
Tim M's Avatar
I'd be interested in this too. Thanks for posting.
Tim M is offline   Reply With Quote
Old 11-09-2019, 08:25 AM   #12
KingLT1
KingLT1's Avatar
Yes they are half and half. The cam lobes for the afm lifters will not work with non afm lifters. It's this way on all DOD/AFM engines going back to LS.
