Amos6.2Jr
Drives: 21 A10 2SS 1LE Join Date: Apr 2017
SS to SS 1LE Tires
Would switching just my rear tires 275 35 20 to 305 30 20 cause any problems?
take offs from a 1LE will fit just fine
Amos6.2Jr
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
According to Goodyear, the min rim width is 10.5” for the SS 1LE tire. The SS rear wheels are 9.5”, so I wouldn’t run them.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
Amos6.2Jr
Oh just the tires...no you can't put a 305 on a stock SS wheel. i meant take offs as the wheel and tire.
#7 |
Amos6.2Jr
Would that be because of the offsets?
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
People have (stupidly, imo) put the 1LE size tires on the stock SS wheels. It's possible.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
dont do it get new wheels that fit 20x10 20x11 is the right size 285/30/20 305/30/20
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
No, don't do it. The wider tire on the narrower rim will pinch the tire, for one. With proper air pressure you will actually have less contact patch on the road and the tire will wear dramatically faster in the center. You could counter this with lower air pressure, however, the sidewall will flex more and the tire will roll on itself when cornering, either way it will reduce stability.
#11 |
Amos6.2Jr
What if i do 305s but in, (SS), 35 20s? If not, what’s the widest tire I could fit on stock wheels?
#12 | |
![]() Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
If you want to run wider tires for cheap, look around on ebay, I just got a set of like new MRR ZL1 replicas in 10x20 and 11x20 for 500 dollars. |
#13 |
305/35 would be even worse because the tires would then be rubbing the wheel liner. Stop. 285/35 is the widest you should go on stock tires.
'16 Camaro 1SS
#14 |
![]() Drives: 2016 Camaro Join Date: Oct 2017
| Tags |
| ss 1le, supersport, tires |
