Old 11-02-2019, 11:57 PM   #1
StormTrooperCamaro
Drives: 2017 Summit White 1SS
Just Installed Flowmaster 40s
So I pulled the trigger on a pair of Flowmaster 40s for my npp system. Startup is amazing and it shakes the ground, as a muscle car should. Drone is a bit annoying at lower rpms at low speed but almost zero on the highway. My only complaint is that at higher rpms the exhaust is quite a bit quieter than the npp. Anyone know of a different muffler that I could swap in that would give me that scream that the npp has at the top end?
StormTrooperCamaro is offline   Reply With Quote
Old 11-04-2019, 02:09 PM   #2
Mighty Mouce
Drives: Camaro
How it sound?
Mighty Mouce is offline   Reply With Quote
Old 11-04-2019, 02:24 PM   #3
StormTrooperCamaro
Originally Posted by Mighty Mouce View Post
How it sound?
It sounds pretty good, super deep on startup but once you really get on it, it looses that iconic scream that the stock npp has. I’m thinking about switching to maganflows, but I’m not sure if they are going to be louder than the stock npp
Old 11-04-2019, 03:14 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That is because on NPP when you go WOT the valves open and bypass the sound damping in the muffler. No true muffler will be louder then bypassing the muffler.
The entire point of NPP is to be able to go from mild to loud. Your setup is now medium to medium. A louder muffler will likely introduce more noise at all rpm range.
MBRP might be what you are after at this point. Loud with no drone...
Old 11-04-2019, 04:02 PM   #5
Spartan268
Spartan268's Avatar
Drives: HB 2SS
You might prefer the Flowmaster American Thunder NPP exhaust. Basically it's a super 40 in "quiet" form and then when the valves open it goes through to the outlaw muffler which is practically straight pipe. This will also retain the muscle car rumble as well.
Spartan268 is offline   Reply With Quote
Old 11-04-2019, 04:44 PM   #6
Mighty Mouce
Drives: Camaro
Please post a video from outside car.
Old 11-04-2019, 06:04 PM   #7
KingLT1
KingLT1's Avatar
That is what I have...it's pretty good. Makes the factory NPP sound like a kitten compared to a lion above 3k rpm, but still civil with valves closed. Does have a little drone right around 1500rpm but I don't have cats.
Old 11-05-2019, 05:47 PM   #8
njweatherman
Drives: 2018 Camaro 2SS, redline edition
I have the flowmaster 817746 (American thunder 409S Stainless Steel) with dual mode exhaust npp. If you want the loudest set-up with NPP, pull fuse 51. Then, the valves never close, and the exhaust will stay in Outlaw the whole time. I think that may be the sound you are looking for. Let me know if you need help with the fuse.
njweatherman is offline   Reply With Quote
Old 11-05-2019, 08:50 PM   #9
KingLT1
KingLT1's Avatar
if you pull the fuse then its no longer NPP. might as well just buy a non npp exhaust and save money.
Old 11-06-2019, 02:20 AM   #10
AdmAnt13
AdmAnt13's Avatar
Drives: '16 Red Hot 2SS M6 NPP
Gotta agree with that one.
Depends on the coin you wanna spend. I bought the Borla Atak with secondary cat delete and NPP compatibility. Louder than the NPP stock setup in all RPM ranges and I can still put it in stealth mode if I don't feel like waking my neighbors..much..
'16 2SS, M6, Borla Atak
AdmAnt13 is offline   Reply With Quote
Old 11-06-2019, 10:09 AM   #11
enzia35
Drives: '16 Garnet Red 1SS
Stealth mode is great with the ATAK. Sadly I wish that I didn't have to comb through all the menus for it, since Tour will still open the valves.
'16 Camaro 1SS
'18 Miata GT
Old 11-06-2019, 10:47 AM   #12
njweatherman
True, but one of the reasons I pulled the fuse was because I could hear the valves open and close. In addition, the NPP valves would rattle and vibrate when closed.
Old 11-06-2019, 11:28 AM   #13
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Engine Masters ( Motortrend series ) recently did a test on noise vs flow ( hp) including baffled type mufflers like 40 series.
ing for grip.
http://www.motorsportsne.com/
Old 11-06-2019, 06:21 PM   #14
StormTrooperCamaro
hey all, thanks for all of the great responses, Ill be posing a vid of the exhaust soon for everyone out there who is considering doing this exhaust. If you don't have the NPP I would definitely recommend it, If you do have the NPP you will be disappointed from what I have found. I ended up buying a used Flowmaster American thunder NPP system a couple of days ago, and I'll be switching them out soon.
exhaust, flowmaster, loud, muffler, sound
