![]() Drives: 2018 Camaro ZL1 A10 Join Date: Aug 2019
ZL1 Rotofab CAI annoying high pitched whistle
I know there’s some old threads on discussions about this but there wasn’t really a solution anyone posted. So like others have talked about in the past...I replaced the stock with a Rotofab CAI. Afterwards, I’m noticing a distinct high pitcher whistle. Super annoying. I have a catback Corsa exhaust on my ZL1...you wouldn’t think you’d be able to hear that whistle.
People of past forums have said its from the angle of the blade in the throttle bottle and having a lot more air pushed harder thru. Some people say it’s the lip of the throttle bottle causing the whistle. Solutions some suggested (1 person) was by replacing it with a ported throttle body it got rid of the whistle. Somebody else replaced with a NW103 and didn’t help. One guy said he shaved down the lip inside the throttle body...and got rid of it. Then everyone else said they either just went back to stock or since it’s “normal” just kept it and got use to it. What should I do? Would a tune help? Throttle body replacement? Any solutions or insight is much appreciated!! |
Bannable
See if someone would loan you a different TB. They are super quick and easy to swap.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I have a ported TB with my Roto-Fab and don't have a whistle. Looks like it's TB time!
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Have you talked to anyone at Vengeance Racing? They are located up where you are in Cumming! I would talk to those guys and see what they recommend!
Or contact Roto Fab via email or PM! They are a vendor on this forum and post things all the time!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
On my 5th gen ZL1 I had the whistle issue with the rotofab. I always swapped it out when I went in for service. This what I learned.
Sure the install is clear cut however, there is ALOT of room for the elbow to be repositioned. By playing around with the elbow closest to the TB, I was always able to stop the whistle.
ZL1::J-E-T-S JETS JETS JETS |
#7 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Do you have the sound tube? If so, an easy fix would be to remove it and eliminate some of the cabin noise.
#8 |
ZL1s don’t have a sound tube!
#9 |
![]() Drives: 2019 ZL1 6MT Join Date: Oct 2016
At first i thought my engine was pinging when I heard that whistle. Is a ported TB a confirmed solution? The whistle doesn't bother me that much
'19 6MT ZL1 | Corsa Xtreme + | RotoFab CAI | NX Lid
#10 |
![]() Drives: 2017 ZL1 Join Date: Jun 2018
Mine does it too. More throttle and it goes away
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
#11 |
Is your really noticeable with the music down and windows down at all? Mine sounds like a squeaky whistle alllll the way down the street.
#12 |
#13 |
If I go throttle body, since I haven’t been able to find anyone in the atl area to swap right quick, any suggestions?
#14 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
Soler TB
| Tags |
| cai, rotofab, throttle body, whistle, zl1 |
