Old 10-31-2019, 07:57 PM   #1
Bob RS
Drives: 2019 Camaro RS 1LT
Winter tires from tire rack
I just got my rim and tires in from tire rack. Took the good advice and made sure all 4 corners are cover with Blizzak tires. Waiting for one key element to come in so I can jack the car up and put them on. But I'm I correct that the 6th gen Camaro does not have stud clips? [ATTACH]1009147[/ATTACH]
Bob RS is offline   Reply With Quote
Old 11-01-2019, 12:54 AM   #2
samr350
samr350's Avatar
Drives: 2017 SS 1LE
Mine didn't have them and if yours does just take them off.
samr350 is offline   Reply With Quote
Old 11-01-2019, 03:16 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
whats a stud clip?
Old 11-01-2019, 07:20 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by JCunningham View Post
whats a stud clip?
Old 11-01-2019, 08:03 PM   #5
RWT
RWT's Avatar
Drives: 2020 Camaro RS
whats a stud clip?
That's funny^^^
Honestly, they are a clip put on one of the lug studs of each wheel to hold the rotors in place during manufacturing. They are not need after production and actually can become a problem. They often keep aftermarket wheels from seating properly.
RWT
2020 Camaro RS, V6, 6MT, Satin Steel
2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray
2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic
RWT is offline   Reply With Quote
Old 11-02-2019, 07:36 AM   #6
JCunningham
Drives: 2017 2SS M6
ok ya i remember seeing the washer kind. i figured thats what you were taking about just never heard it called a stud clip befor. GM uses a screw now. i like the screw.
Old 11-02-2019, 11:15 AM   #7
L8Apex
Drives: 2016 2SS
The screw that keeps the rotor flush?
L8Apex is offline   Reply With Quote
Old 11-02-2019, 10:19 PM   #8
Frank237
Frank237's Avatar
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS
4 BLIZZAKS! That thing will seem like 4 wheel drive!
Frank237 is offline   Reply With Quote
Old 11-03-2019, 04:02 PM   #9
tomlink
tomlink's Avatar
Drives: 2011 Camaro 2LT RS
Send a message via Skype™ to tomlink
Yes, and I was surprised how easily that screw came out after 80K+ miles on my 2011. Getting the rotors off was not so easy. But a couple of taps with a 16lb sledge took care of it. The brakes actually did not need replacing, but I was getting a pulsation on braking from rotor warp.
tomlink is offline   Reply With Quote
Old 11-04-2019, 04:43 PM   #10
ste1n
Drives: 2019 2SS
I have blizzak tires too on 18" wheels. What's the tire pressure are you guys running?
ste1n is offline   Reply With Quote
Old 11-04-2019, 06:51 PM   #11
chevybill
Drives: 1994 z-28, 2017 2ss 6spd
How do you accommodate for 4 different tpms sensors in those winter tires?
chevybill is offline   Reply With Quote
Old 11-04-2019, 08:18 PM   #12
ste1n
Drives: 2019 2SS
Like initializing the tpms sensors in the winter wheels?
Old 11-06-2019, 08:44 PM   #13
Bob RS
TPMS Winter Tires
Tire Rack install tpms sensors also into the new rims I have a tpms GM relearn tool so when all you have to do is go to your settings and find your tire pressure leave it there and press ( SEL) it will set off tire pressure relearn then you start with the left front then right front then right rear and finally left rear and the car horn will sound off 2 times telling you the system has relearn the new tpms.
Old 11-07-2019, 06:21 AM   #14
dray
dray's Avatar
Drives: 2017 2SS A8 NGM, 2012 Yamaha FZ8
Those wheels look great! I wish I'd gotten 19" instead of 18", but at the time the 18" were alot cheaper.
dray is offline   Reply With Quote
