Old 10-31-2019, 05:12 PM   #1
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Flex Fuel Kit
Local tuner said I could run full E85 on my lt4 no problem with long tubes, cai, ported TB, and a tune. I did a search and it seems some people are saying that it will work, others that it wont. I'm wondering if this is because the LT1 might be different on the low side than the LT4? Curious how many guys are running full E85 on stock fuel system with no issues (on lt4). Thanks for any info!
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 10-31-2019, 05:32 PM   #2
big dave
Drives: 2017 ZL1
From what I've read, I don't think you'll be able to run full E85 because the fuel system wouldn't support it with those mods. You may be able to get away with E50.
I've been researching a similar setup for my car so I'll be subscribing to this thread to see what others say.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 10-31-2019, 06:14 PM   #3
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Get the E85 kit from Ted Jannetty, he can enable it and tune for you.
ssmofo is offline   Reply With Quote
Old 10-31-2019, 06:51 PM   #4
TJay74
A ZL1 even with the full LT4 fuel system from the factory wont be able to run full E85, the fuel system doesnt have enough headroom. The lowside is fine, the high side (high pressure pump) cant keep up.
E50 is about the limit on the stock stuff until you put in a cam with a +32% fuel lobe.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 11-01-2019, 12:20 AM   #5
Dixie ZL1
NOXQCES ZL1
Similar mods and E40 is the limit. At E40 there’s no discernible HP or TQ improvement I’m going to add an aux pump to run full E85.
Dixie ZL1 is offline   Reply With Quote
Old 11-01-2019, 01:00 AM   #6
Jason18ZL1LE
Drives: 2018 ZL1 1LE
That’s not entirely accurate. The high side pump is fine, but only if you use a proper cam for it, your wording makes it sound as if even after a cam the LT4 isn’t enough and that’s false.
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq
ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid
Jason18ZL1LE is offline   Reply With Quote
Old 11-01-2019, 07:13 AM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
flex fuel sensor and enabling the tune is an easy way to gain 30-40hp with almost no effort. The problem with the tune is obvious (warranty) but it is tempting. I did this in my 2018
Silverado 6.2 and the results were amazing.
Old 11-01-2019, 11:41 AM   #8
Jason18ZL1LE
Thats true for Silverado LS and SS/LT1 however the LT4 is already nearly out of fuel with the incredibly small cam lobe.
A ZL1 owner cannot simply bolt in a flex fuel sensor and run it. To TRULY run E85 you NEED additional cam lobe at a BARE minimum a fuel pump voltage booster (DSX lowside is highly recommended rather than overvolting the stock pump) to keep the car safe.
Old 11-01-2019, 04:56 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
as stated above and I believe Jannetty has shown E50-60 can be safely run with the stock fuel pump, cam (fuel lobe), etc and not be any issue. Obviously, log your data after install to confirm all parameters are in range.
Old 11-01-2019, 05:13 PM   #10
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
Where did you get the sensor for the 18 Silverado? I've been thinking of doing the same to my 18 Tahoe 6.2.
7LitreC5 is offline   Reply With Quote
Old 11-01-2019, 07:08 PM   #11
Stephen12ZL1
Drives: '21 ZLE A10
https://youtu.be/YIfBSlPJwr8
https://youtu.be/ezb58gNGJRk
https://youtu.be/O_WeWK06zWM
Old 11-01-2019, 07:27 PM   #12
Stephen12ZL1
Drives: '21 ZLE A10
Watch the videos above and his tutorial is very good. You have to enable the tune which is the most annoying part. The good thing is GM already has all of the tables in the tune...they just aren't enabled in the 6.2 vehicles. I Purchased the sensor from Amazon and it is the same sensor that's for a 2011 impala flex fuel 3/8". Get the GM part (continental) and not the cheaper version as the first sensor I received was dead. If you do it like the guy installed it in the video there was no cutting or splicing required. My truck is a standard bed crew cab so I had to get an extension harness to reach the sensor location.
Old 11-01-2019, 08:05 PM   #13
TJay74
My wording and info is correct, I have the full LT4 fuel system from the gas tank all the way up to the engine on my car. It is supercharged and puts down 650rwhp on E50.
On the stock cam if you have the full LT4 fuel system the low side will be fine, it will hold 70psi with no issues. The high side pump will run out at WOT high rpms and wont be able to hold more than 2500psi from around 5750rpms until the rev limiter at 6500rpms.
As I said, once you add a +32 fuel lobe cam to the setup it changes everything, but you will still run into issues being able to run full E85.
Old 11-01-2019, 09:43 PM   #14
7LitreC5
Thanks. I'll take a look under the Tahoe when it warms up her and make sure that it has that pigtail. Installation looks super easy in the videos.
