Old 10-29-2019, 01:44 PM   #1
Azure_King
Drives: 2016 Camaro SS
Exclamation Misfire at 3k rpm, Help!
So, new to the forum, nice to meet everyone!
I have a 2016 Camaro SS with 57k on the clock; It has a misfire on cylinders 5&8 between 3-4k Rpm.
So far I have replaced all fuel injectors, the fuel pumps and the ignition system(plugs, wires, and coils) this has been an issue since i bought the car a year ago and I’ve taken it to two chevy dealers and they can’t seem to figure out whats wrong.
Recently I reset the torque on all the rocker arms just incase something was too tight and to make sure i didn't have a weak or collapsed lifter...
Any Ideas? Thanks in advance!
P.s. the car is stock aside from long tubes, and a tune.
Azure_King is offline   Reply With Quote
Old 10-29-2019, 01:51 PM   #2
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
I would suspect the tune if you have changed all that, does it bring on the CEL?
ssmofo is offline   Reply With Quote
Old 10-29-2019, 02:50 PM   #3
Wilka_SS
Drives: 2016 Nightfall Metallic Grey 2ss
Check for a broken valvespring or carbon collected on either of the intake and exhaust valves preventing the valve from seating and sealing.
Wilka_SS is offline   Reply With Quote
Old 10-29-2019, 03:01 PM   #4
Azure_King
@SSMoFo- this has been an ongoing issue since the car was bone stock; CEL flashes but doesn’t stay on.
@Wilka_SS- None of my valve springs appear to be cracked or broken... I’ll have to check throughly for carbon buildup on valves.
Old 10-30-2019, 09:28 AM   #5
sal11585
Drives: 2017 Camaro SS 2ss Nightfall Gray
I am no expert , but maybe its something electrical . Maybe the wiring to the coils or something. Especially since its always done it and looking at what you replaced already, I cant think of anything else it could be.
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels
Roto fab Biggulp CAI
Full paint correction with cquartz finest ceramic coating
Whipple 2.9
ARH Long tube headers with High flow cats
1le sway bars F&R
BMR Upper and lower trailing arms
Hurst short throw shifter
sal11585 is offline   Reply With Quote
Old 10-31-2019, 07:05 AM   #6
Cechk01
Drives: 2016 Camaro 2SS M6
it should still be under powertrain warranty, tell the dealer to fix it
Cechk01 is offline   Reply With Quote
Old 10-31-2019, 07:49 PM   #7
Azure_King
Everything looks fine visually... I’ll put a multi meter on the harness this weekend just in case...
Old 10-31-2019, 07:52 PM   #8
Azure_King
My warranty expired a couple months ago.
However, I have a 3rd party extended warranty that covers what chevy would in their powertrain warranty(all internally lubricated parts, not including injectors).
Old 10-31-2019, 08:45 PM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Waitasecond....How is a 5/60 warranty expired already at max 4 years and 57k miles?
Edit: nevermind, I see you have a tune.
Old 11-01-2019, 05:25 PM   #10
Azure_King
Good eye, but my dealer didn’t care about the tune...
Edit: Checked my e-mail again; the notice was to let me know my warranty was expiring soon
Old 11-02-2019, 08:47 PM   #11
Azure_King
Update: As of right now there is no more misfire, we’ll see what happens when I take her back to the dyno...
Things I did: checked all wiring from the ECM to each coil(no issues found), checked all ECM fuses and relays(no issues found), Replaced all pushrods and re-gapped spark plugs from .040 to .035.
Thanks for the input guys!
Old 02-06-2020, 09:59 PM   #12
Azure_King
Update: Maybe I can save someone a headache later down the line
So, the misfire came back a few weeks after the aforementioned parts were replaced
So, I took my time and diagnosed a little better....
Misfire only happened at 3k or higher steady state throttle.
I already ruled out the ignition system, fuel system, and the possibility of damaged lifters push rods and valves.
So... I ended up marking my valve springs with a paint marker and gave her a good rev to 4k and lo and behold.... My valves were floating (photos attached)
Hope no one else runs into this issue, but on the bright side the LT1 is a non interference engine in stock trim
Good Luck out there and remember to be thorough when troubleshooting.
Old 12-09-2024, 04:23 PM   #13
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Probably a Necro, but had a question:
I've been having a misfire issue on my car, and I am wondering if I might have the same issue.
Car only seems to misfire under load over 3000 rpm and always right before or after a shift even at high rpm's.
And it happens on two different tunes, a conservative tune, and my more aggressive tune.
The car ran fine on the aggressive tune up until May 8th or so of this year 2024.
I've swapped back and forth between the conservative tune and the aggressive tune. The misfires are worse on the aggressive tune, but still present on the conservative tune as well.
I hear a sputtering in the exhaust. While on the aggressive tune I get a loss of power along with the sputtering, on the conservative tune, I don't really get a loss of power but can still hear the sputter on the conservative tune.
Original Rebuild parts list:
I've already had the car checked for the below:
1. Replaced spark plugs twice original sparkplugs were NGK-LTR7 after the engine rebuild with NGK-LTR5 I was told to switch to LTR6 instead
2. Replaced both upstream left/right O2 sensors
3. Replaced Plugwires
4. Car in shop - No Leaks, 160-170 psi compression test, had coils checked, and injectors (although for injectors they only checked for wet spark plugs) Shop said they couldn't find anything mechanical wrong with the car, but no idea if they bothered to check for Valve float.
5. Don't believe it is a fuel pressure issue according to logs fuel pressure seems to be where it should be.
I suspect valve float because I assume the valves are original stock with upgraded dual valve springs from BTR.
Would this be a fair assessment in my case?
Would this be something to check?
Also have a log or two of mild pulls at about 3000-4000 rpms which is when I start to hear the sputter after the shift.
Old 12-10-2024, 06:52 AM   #14
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Fluke - did you do a crank sensor re-learn? Whenever I hear someone having higher RPM breakups that is the first thing I think of. That was always a thing on the LS engines. Not sure if the LT engines are the same.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
engine, misfire
