Old 10-28-2019, 04:49 PM   #1
CamaroSS50
Drives: 2017 Camaro Convertible SS Fifty
MyLink issues...
Not a major issue, but a real PITA.
Issue 1: My private drive is well shaded, so in the AM when I drive through it, which is maybe 10 feet of shade, the screen, etc. goes to night mode. Problem is, as soon as I am out of the shade, I am in blaring sunlight and the screen stays dark for a long period of time and as soon as I hit direct sunlight, and I mean the blaring sun, will it come back to day mode.
Issue 2: CarPlay. This is driving me somewhat nuts. MyLink will read that my iPhone is connected, but still not allow me CarPlay access. It takes unplugging the phone multiply times to get it to appear. Sometimes in the middle of a drive it will simply go black and not return until I turn the car off and restart, which is an issue on the highway...
Any ideas?
2017 Camaro SS FIFTY Convertible
CamaroSS50 is offline   Reply With Quote
Old 10-28-2019, 05:32 PM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I had the problem with Car Play and it was the cord. The sensor for the day night is on the dash. Annoying but it is what it is.
dpevans is offline   Reply With Quote
Old 10-28-2019, 05:52 PM   #3
HighIron
Drives: 2024 2SS Summit White
Word. It was Android Auto for me, and an inferior quality cord was the culprit. It's not that AA didn't work, it just worked badly, and intermittently.
Took me some time to connect the dots to figure out that was the cause.
HighIron is offline   Reply With Quote
Old 10-28-2019, 06:12 PM   #4
Aragorn
Drives: Camaro SS 1LE
CarPlay issues here. For me I think mylink gets confused with Bluetooth connectivity versus CarPlay. Sometimes when I’m patient enough to deal with the issue I’ll just turn Bluetooth off on my phone and cp usually works. The problem is that soon after Bluetooth will turn back on.
Aragorn is offline   Reply With Quote
Old 10-28-2019, 06:26 PM   #5
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
2018, iPhone and I'm having the same issues. I've been through two new OEM cords and an aftermarket with negative results. The bluetooth angle is interesting and I will give that a go in the AM. I chatted with the dealer this weekend and they said to drop by during the week and they will update/verify the software version and see if that helps.
Warrior102 is offline   Reply With Quote
Old 10-28-2019, 07:15 PM   #6
Any ideas?
Unfortunately issue 1 seems to be the norm, more recent sunlight sensor input delta takes precedence very slowly in my Camaro and other GM cars, too. Probably a trivial fix, but one can't touch this code, unless somebody with insider info cracks it.
Old 10-28-2019, 08:42 PM   #7
Crysiswar6
Drives: Chevrolet Camaro
I haven't seemed to have had any of these same issues with my new 2019 1SS. Other than an unrelated issue of anyone I'm talking to on the phone through the car stereo gets a decently loud clicking that doesn't stop unless i'm speaking.
Crysiswar6 is offline   Reply With Quote
Old 10-28-2019, 11:48 PM   #8
KirkH
The USB port in the console is not very stable. I had the CarPlay connecting/disconnecting thing all the time.
There are some threads on here where people solved the problem by replacing their USB port with a new one.
https://replacementradios.com/gm-201...42-p-3256.html
https://www.camaro6.com/forums/showthread.php?t=555181
Old 10-29-2019, 12:29 PM   #9
martelds
Go Arizona Cardinals
martelds's Avatar
Drives: 2006 GMC Duramax 2500 HD, 2016 2SS
I also had the same issue, but a new cord and sometimes I have to delete the current apple play configuration. Delete the phone and let it reconnect. I still loose connection sometime still but not very often.
2015 Nissan Murano SL with Tech Package
2006 Lifted GMC Duramax 2500 HD. Lot's of custom parts!
2016 2SS Garnet Red 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Black Rally Stripes, NAV, Sunroof, Corvette Z51 Black Wheels, Black Front Fascia, aFe / PFADT Suspension Lowering Springs, Black High Rise Rear Spoiler. High flow headers, E85, Roto-Fab Cold Air, MSD Atomic AirForce Intake. aFe / PFADT Front & Rear Sway Bar. Pushing 520 to the Rear Wheels
martelds is offline   Reply With Quote
Old 11-01-2019, 10:16 PM   #10
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Try to connect the iPhone before starting the car. Never had issues doing this way (iPhone X and now 11 Pro Max).
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
