![]() Drives: 2017 1ss 1le Join Date: Feb 2018
Mechanical overrev
Hi guys had a track day a few days ago and hit 2nd instead of 4th. I know stupid. Anyways it was caught on my pdr. I backed off as soon as I realized it which was really quick. It was my last session and the final lap of course. Drove it 2 hrs back home and didn't notice anything. Think I'm ok?
![]() Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
90 in second gear should be about 7400rpm based on quick math and stock tire diameter. That doesn't sound too bad to me.
If it doesn't seem down on power and isn't making any scary noises, you're probably ok. Maybe change the oil and check the filter for any bits. |
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
If you caught it right away I'd venture to say you're fine. I've done it a few times over the years and caught them right away; not once did I have any engine issues for any of those cars.
No ticking/tapping coming from the engine afterwards right?
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Id bet that your fine. I've done it a few times in my going on 18 year old LS1 and its never had a problem.
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Most believe over-rev damage is incremental. Likely valve springs are most impacted - lose pressure once exceed their design limits.
Obviously, if it didn't scatter - no issue, but don't think anyone can guarantee long term health...then again, a production engine is pretty robust - few LT1's seem to be have been lost.
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
If it's burning a lot of oil in the next 1000 miles or so you'll probably be rebuilding the head.
Not every issue makes itself evident immediately. |
#7 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
Remember, you can do the same by downshifting to the correct gear but letting the clutch out too early. Active rev match won't save you on that either. I see it all the time in PDR videos. As mentioned, you may not drop a valve right away, but, you're poking the hornet's nest a little at a time.
#8 |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2017
Jonny, I wouldn't worry too much... Red line is 6500RPM and it looks like you went just 500 above for a bit.. As others said, it did not grenade itself right then and there.. get an oil change and it should be good for 17 Nov Sebring!
Tango Charlie
'18 1SS 1LE '68 SS LS2 '89 RS 'vert |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Id swap out the springs, as a proactive measure.
#10 |
Thanks for all the info. Engine is running fine with no lose of power, smoke, or ticking. I am going to change the oil this weekend. Tango I am a no go for the 17th. Going out to auto club speedway (cally) for a hpde in a c7 grandsport. Cant wait to compare to our car. Hopefully Jan we can meet up again
#11 |
Thank you Al Oppenheiser!
Send a sample to blackstone and tell them you money shifted it. If there is metal in the oil, they’ll tell you.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Keep driving it, you are fine. I wouldn't worry about it for second unless you have heard something different.
#13 |
Just some food for thought: you could be fine, or some parts, springs especially, could have gotten fatigued.
Nobody can tell you one way or another, not even if they are a Grand Master Mechanic, or a BB poster ![]() The fact you dont hear anything is a sign nothing broke immediately, but not that something wont break next time you reach red line, if it has weakened. Metal fatigue is not a binary type of proposition a la: it works today so it will work just fine tomorrow. I know semi pro circle track guys who change springs for every race, as a cheap insurance. Usually, 4th to 2nd will grenade a motor in an instant, but perhaps your shift was a lazy one, allowing rpms to drop quite a bit. Regardless, I wouldn't say you're risk free longer term. My 2 cents. Then again, you are covered by GM power train warranty, so there is that Cheers!
#14 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
^^^This. Easy to do. Peace of mind is worth the minimal effort.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
