Old 10-28-2019, 02:15 PM   #1
C Man
Drives: 2018 White Convertible Camaro ZL1
Creaking sound as it gets colder :s
I've been having this issue since new. The minute the weather gets a little colder, the roof starts creaking.
It's the same with the windows up or down.
I thought it was where the rubber weatherstripping was connecting along the roof line because that's where I am hearing it. However I used a little bit of grease to lubricate the 2 main joints and still creaking.
Very annoying when driving.
Anyone have a thought or experience this problem?
White 2018 Camaro A10 Convertible ZL1
C Man is offline   Reply With Quote
Old 10-30-2019, 07:26 PM   #2
Ajs16400
Drives: 2017 Camaro SS Convertible
Started hearing it as well. Not a clue what it is or tried anything to fix. Just thought it was normal.
Ajs16400 is offline   Reply With Quote
Old 10-30-2019, 11:17 PM   #3
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Yes, and it drive me mad as well!
STYLO LT1 is offline   Reply With Quote
Old 10-31-2019, 12:40 AM   #4
c4racer
Drives: 2016 SS Convertible
Hmm. I haven’t noticed it. But I don’t drive with top up much.
I did tonight. Didn’t hear anything like that Over the exhaust !!
c4racer is offline   Reply With Quote
Old 10-31-2019, 11:42 AM   #5
C Man
I can't believe nobody has been able to figure out the problem or even address it.
My wife as a Mercedes convertible... and absolutely no issues with hers. So I don't think it is common in convertibles.
I may ask the dealership when I'm in next time for an oil change.
Old 11-01-2019, 10:34 PM   #6
Ruebernard
Ruebernard's Avatar
Drives: 2023 Radiant Red Tintcoat 2SS
Don’t waste your time. Took mine in two times. The last was today. The first fix worked for a day. The day after, worse that when I took it in. Today after 8 hours in the shop. It’s back to the the noise I brought it in for. Chevrolet service sux.
If it were more fun, it would be illegal!
Ruebernard is offline   Reply With Quote
Old 11-29-2019, 06:27 PM   #7
arocars
Drives: 2017 Camaro SS w/ 2SS
I own a '17 SS conv. In the past, I owned a 69 Lemans conv, 94 Z28 conv, and 09 CLK conv. I found that inevitably, the top will start making noise as the seals shrink due to the cold and things rub together more. ... I've read you're not supposed to use things like Armor All or similar silicon based sprays, and definitely nothing with a petroleum base. ... I also read the BMW makes a spray for their convertible top squeaks. Good luck.
arocars is offline   Reply With Quote
Old 11-29-2019, 10:38 PM   #8
Oddspyke
Drives: 2018 Chevy Camaro ZL1 convertible
I haven't used it on my convertible yet, but gummi pflege worked wonders on my other car. Once a year is enough to keep the door and sunroof seals quiet and well conditioned.
Oddspyke is offline   Reply With Quote
Old 11-30-2019, 02:09 PM   #9
Blue_6.2
Blue_6.2's Avatar
Drives: 2019 1SS Convertible
https://www.autogeek.net/1z-einszett...are-stick.html
It's from Germany, so you know it's ... well, it's from Germany.
Blue_6.2 is offline   Reply With Quote
Old 11-30-2019, 03:41 PM   #10
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Same stuff on Amazon
https://www.amazon.com/nextzett-9148...5146382&sr=8-1
17rsvert is offline   Reply With Quote
Old 12-02-2019, 11:20 AM   #11
EddyC
Drives: Chevy Camaro 2SS
Always used this on my BMWs (Z4 and E93) and it worked great, been using it on the Camaro for the past few months (2 or 3 applications) not managed to stop the wind noise from my driver side window but certainly not getting many squeaks from the seals. Also it's a great protector which is super important in AZ.
EddyC is offline   Reply With Quote
Old 12-04-2019, 06:33 PM   #12
wintertopdown
Drives: 22 Convertible V8 LT1
I drive with the top down in the winter all the time!
wintertopdown is offline   Reply With Quote
Old 12-04-2019, 08:41 PM   #13
discgolf01
Drives: 2018 ZL1 Convertible M6
Does it sound like a plastic on plastic contact or "ticking" noise? If so, I had the same thing - try pressing your fingers in the gap between the top's plastic trim and the plastic header on the windshield - if the noise goes away, its the same thing I had.
At first I thought it was the vertical plastic surfaces rubbing on the each other, but eventually figured it out to be the horizontal surfaces of the top's plastic trim and header trim. I put a 1" wide adhesive felt strip along the entire length of the top's piece and the problem has pretty much disappeared.
discgolf01 is offline   Reply With Quote
Old 12-05-2019, 06:05 PM   #14
c4racer
you guys need louder exhaust systems!
