Old 10-22-2019, 07:29 AM   #1
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Issue with 10" race ramp cribs
It seems my jack only gets up to 19 1/2" inches which was not enough to get the 10" wheel cribs under the wheel. I just used regular jack stands for the 1st oil change. Do you guys with the cribs use wood blocks under each wheel to get the clearance or do I need a jack that gets over 19 1/2" inches?
getchapull is offline   Reply With Quote
Old 10-22-2019, 09:21 AM   #2
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
If only you would have got the 8" cribs like I recommended...
Now you're stuck either getting a new jack or elevating the jack an inch or two before lifting the car which is sketchy.
djfury05 is offline   Reply With Quote
Old 10-22-2019, 01:22 PM   #3
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Just get a 2x12 inch board and cut it up to put under the jack.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 10-22-2019, 08:21 PM   #4
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
What brand jack are you using? I have the Daytona low profile it says max jack height of 23 inches. Haven't tried it yet and was looking into the race ramp blocks for my car. I might have to get the 8in
Zigg L1 is offline   Reply With Quote
Old 10-22-2019, 09:08 PM   #5
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Pittsburgh Automotive 3 Ton Heavy Duty Ultra Low Profile Steel Floor Jack with Rapid Pump Quick Lift
Max height is 19 3/4" or so.
