Old 10-17-2019, 12:03 AM   #1
Oak78
Drives: 2018 ZL1 1LE
SS 1LE vs. ZL1 1LE suspension
What are the differences between the suspension of the SS 1LE and the ZL1 1LE suspension and brakes? I’ve been searching but cannot find a definitive answer? I apologize if this has already been answered I cannot find anything.
Oak78 is offline   Reply With Quote
Old 10-17-2019, 12:06 AM   #2
Bhobbs
Bhobbs's Avatar
The SS 1LE uses MRC shocks. The ZL1 1LE uses DSSV shocks. Also, the ZL1 1LE replaces some bushings with aluminum, if I remember right.
Old 10-17-2019, 12:07 AM   #3
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
SS 1LE has MagRide, probably similar to the ZL1.
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 10-17-2019, 12:23 AM   #4
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Think of it like this,
Regular SS
ZL1 and SS 1LE are roughly the same in terms of suspension/brakes, a significant step up from the SS. The ZL1 is far more than just a blower on the engine, but the SS 1LE is basically the ZL1 minus the engine, also a bit better balanced with less weight up front. A few details are slightly different due to the difference in weight between the two.
Then ZL1 1LE at the top as the most track-focused.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 10-17-2019, 12:41 AM   #5
Oak78
When I searched Dssv I was able to find the difference. It seems they can be purchased and installed but I’m sure it would cost a fortune and not really worth it unless it’s going to be used mostly or completely for track. Still nice that they offer them in the Chevrolet performance catalog. Thanks for the info.
Old 10-17-2019, 12:49 AM   #6
nicktechla
nicktechla's Avatar
https://wildhammermotorsports.com/ca...t-performance/
IG: 2fast2nick
-- Current --
-- Past --
Old 10-17-2019, 12:56 AM   #7
Oak78
That’s actually less than I expected it to be but probably not a good idea for a car that is mostly driven on the street. Especially California streets.
Old 10-17-2019, 08:30 AM   #8
TJay74
While the SS 1LE has the upgraded Corvette Z06 brakes, they are slightly different than the ZL1 or ZL1-1LE. The front calipers on the ZL1 models are different and the front rotors are different as well.
If my memory is right, the front spring rates are different from the SS to the ZL1 because of extra weight of the supercharger. The rear diff is the same for all 3 models other than the axles are different and the calibration for the eLsd is different.
Other than that as said the ZL1-1LE uses the DSSV shocks and has different bushings than the SS 1LE and the ZL1.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 10-18-2019, 01:10 AM   #9
Chevyfan4life
The Green Hornet
Chevyfan4life's Avatar
Drives: 2020 Rally Green 2SS 1LE
The Zl1 1LE also has the adjustable camber plates and the SS 1LE/ZL1 does not.
XCMKZ4- 2020 Rally Green 2SS 1LE
1100-07/02/19
3100-07/04/19 | TPW 8/5
3400-7/29/19
3800-8/2/19 Built!
4300-8/5/19
4300-8/9/19 delivered to rail yard
4200-8/13/19 Shipped!
5000-8/19/19
6000-8/24/19 She's Home!
Chevyfan4life is offline   Reply With Quote
Old 10-18-2019, 08:44 AM   #10
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
That doesn't include MRC delete boxes or anything like that. I'm not sure what trim of Camaro you're looking at getting. But if you install ZLE suspension on something with MRC for example, there are other things needed.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
