![]() Drives: Chevy Camaro 2SS Join Date: Sep 2019
C7 supercharger on LT1 block
Hey guys, I’m new here so sorry if these are dumb questions, lol. I have a 2016 Camaro ss and my buddy is selling his lt4 supercharger off of his c7 which includes the throttle body. I’m aware that I’ll need adaptor plates to make it fit, as well as a snout adaptor due to the c7’s being a bit longer.
What parts or components will i need in order to make this swap necessary? The reason I’m going which this supercharger is because he’s giving me great deal on it and i don’t want to have to spend a fortune on a “conversion kit”. Thanks guys(: |
In order to make this swap possible* my bad
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
It's not as easy as you would think to swap out the snout. It should be technically possible, but it would be easier just to get the right blower. I have an LT4 blower sitting in my office right now ready to be installed on the Vette. I bought a new blower off a Camaro and it doesn't work because the pulley alignment is shorter (The Camaro LT4 blower has an upper pulley that sticks out too far. You can't use spacers to get the lower pulleys lined up because there isn't enough room. I think it was the steering column or something (let's say you would need an extra inch...can't do it.
So, you are stuck getting the upper supercharger pulley pulled back to allow the alignment to work. It's been a bit since I went through the entire ordeal. . .and it really depends on if you have the wet sump or dry sump setup. If you PM me, I can send you pictures or point you to some other threads where you can get all of the details. On my setup, I ended up paying to get a ported blower and they changed the snout to make it work.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 10-14-2019 at 10:48 PM. |
#4 | |
1. Getting a custom pulley made than would essentially bolt on and slide back over the snout bringing the pulley into the right alignment with the lower pulleys. You can't bring the lower pulleys out because there isn't enough room. In checking to get this done, I didn't find anything that would really work without also fabricating or cutting into the blower. Not saying it can't be done...but definitely not worth the effort. 2. On the older blowers, the snout can be swapped. The problem is that GM doesn't sell the part by itself. To fix the problem, I sent my blower off to have it ported and as part of the port, he swapped the snout on my blower with another blower he had sitting on the shelf. I guess he was selling them for the same price Camaro or Vette. Technically, I did exactly what you are saying. I have a new Camaro LT4 blower going on my Stingray. I can connect you with the person that fixed it for me if you would like to try and talk to him before you make a decision. Here is a picture of the difference. Look at the pulley location on each of these blowers. The LT4 blower from the Camaro sticks out about an inch past the snout on the Corvette.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 10-14-2019 at 10:58 PM. |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
As far as I understand the OP is trying to fit an OEM C7 (Z06 / LT4) blower onto his 2SS.
![]() Drives: '99 Vette, '02 SVT Focus Join Date: Feb 2018
There are pulleys available that compensate for the difference going from Corvette to the Camaro belt line.
#7 |
Yes it will work with the right off set for the pulley and a few other things. I would contact ADM performance being they specialize in OEM blower swaps.
#8 |
My bad. I totally misread. Yeah, so the picture I posted shows the corvette offset on on blower and the Camaro offset on the other. The Camaro sticks out about an inch further. So, if you had the Corvette blower with the short nose there might be an option to get a pulley or spacer to take it out further and get on the Camaro belt line. That would definitely make sense and should be much easier unfortunately I can’t answer for sure.
You could do something like I did. Pay for a porter blower and ask if they will swap the nose as part of the job.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
| Tags |
| camaross, corvette, forced induction, lt4 supercharger, supercharger kit |
