Old 10-10-2019, 08:59 PM   #1
Goohead
Horsepower whisperer
Drives: Camaro
4” stroke clearance? Lt1/lt4 Block difference
Had 2 questions:
What if any clearance modification needs to be done to the block for a 4” stroke crank
Anyone know what the difference in the lt1/lt4 BARE block?
Lt1 part #: 12619171
Lt4 part#: 19329617
Thinking about a winter project if I keep the car and wanted to see if anyone can help me answer these 2 last points.
Lastly, aside from on the loose side of spec, does anyone have any bearing clearance, ring gap recommendations for ~15-18lbs of boost? Thanks
Goohead is offline   Reply With Quote
Old 10-10-2019, 09:42 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
This doesn't answer your question, but More stroke is the last thing you need for boost engine.
Old 10-12-2019, 12:01 AM   #3
Goohead
Drives: Camaro
Thanks, just looking for the facts to the question above
Old 10-13-2019, 07:54 PM   #4
Goohead
Drives: Camaro
So one thing I found out; it seems piston oil squirter will need to be removed or the block machine for some 4” stroke clearance ones Katech sells. Alternative might be able to just plug the squirters and not run them. Less piston cooling, more bearing oil pressure...
Old 10-13-2019, 09:59 PM   #5
Puddin
Talk to Texas Speed as they still use the Piston squirters too.They just did my 427 shortblock and answered all the questions I asked so I don't see why they couldn't answer yours.
Old 10-19-2019, 11:16 AM   #6
Goohead
Drives: Camaro
Don’t know if they will freely give someone info that’s didn’t plan on using them to build the block?
Wanted to do some research before jumping in, do the build in a “home” garage and post up a walk through after wards.
Didn’t know if there things I would run into:
Rod BE clearance to bottom of sleeve
Piston skirt to squirter clearance (issue found)
Reluctor wheel clearance
Cam clearance
Main fillet bearing clearance on aftermarket crank
Ultimately I was going to document the journey for anyone else that wanted to tackle this in the future and was going to leverage this community to share some knowledge.
