Old 10-09-2019, 06:33 PM   #1
CamaroSS50
Drives: 2017 Camaro Convertible SS Fifty
A8 Shudder, etc. TSB 18-NA-355
Might be here, but had a time finding it, it is 17 pages long.
Printed it out and taking it with me for the dealer.
https://static.nhtsa.gov/odi/tsbs/20...63890-9999.pdf
2017 Camaro SS FIFTY Convertible
CamaroSS50 is offline   Reply With Quote
Old 10-09-2019, 06:51 PM   #2
AutoPenalti
Drives: 2017 Chevy Camaro 1SS
Not sure if I’m having the rumbling or shudder issue, I’ve noticed when on manual and decelerate to 1st gear the car noticeably jolts. Not sure if related.
AutoPenalti is offline   Reply With Quote
Old 10-09-2019, 07:14 PM   #3
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
From my understanding the shudder is only when you're in a higher gear and steady throttle or lightly accelerating
HCI2000SS is offline   Reply With Quote
Old 10-10-2019, 03:09 PM   #4
MANNAXMAN
MANNAXMAN's Avatar
I've posted this link in several threads, including the TSB Sticky in this subforum.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 11-20-2019, 03:31 PM   #5
CamaroSS50
Anyone able to point me to the TSB where they are to replace the converter or whatever as my dealer is refusing to do so as they cannot replicate the issue.
Thanks.
Old 11-20-2019, 04:14 PM   #6
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
Thanks.
Sorry, I can not help with that. Last I heard, it was probably no way they replace the TC.
What I can note is, I told my service department if they were unable to duplicate the problem, I wanted to schedule an appointment for them to do a 'ride-along', with me driving the car. And not have it just returned to me, unchanged. (Since I could duplicate the problem almost on demand.)
As for the rest, on the second visit, they duplicated the problem and did the flush. I'm a few thousand miles past that and, luckily, has not returned. I also scheduled a ride along for when I picked it up, for assurance that it was actually fixed.
For what it's worth.
It's a pita, but keep after it.
Eric10905 is offline   Reply With Quote
Old 11-20-2019, 04:34 PM   #7
HCI2000SS
HCI2000SS's Avatar
TSB 18-NA-355 is the one you want, but it also states to not replace the torque converter. With that said I was able to get mine replaced with the fluid/flush. It's likely dealer dependant. In my case the dealer saw the metal shavings in the fluid from the torque converter clutches, so they told GM, and they said to go ahead and replace it
Old 11-20-2019, 05:38 PM   #8
CamaroSS50
Here is the down side.
They did the fluid change, it came back within 500 miles.
Now they are saying they can't re-duplicate it therefore nothing is being done.
Had thought that if it returned after 500 miles that the next remedy was replacing the TCC, clearly I am wrong.
Old 11-20-2019, 06:42 PM   #9
ScatPack
ScatPack's Avatar
Drives: None at the moment
In your case this is the dealer not wanting to eat a second round of repair. They have to warranty the repair for 12/12 that they got paid from GM for. A return to the dealer for the same problem, means its coming out of the tech's and the dealer's pocket. The tech likely doesn't want to do the repair again on his own dime.
The kicker is no other dealer will touch it until after that 12/12 goes by. They would also be paying out of pocket for the repair because the other dealer would be expected to redo the repair under their warranty. This is the shit part of dealers. You are best served to suck it up buttercup, and pay for an aftermarket TC to be installed. No more shudder.
ScatPack is offline   Reply With Quote
Old 11-20-2019, 06:46 PM   #10
CamaroSS50
Not following, are you meaning December 12th?
And if I install an aftermarket TC won't that void the warranty?
Old 11-20-2019, 08:15 PM   #11
RWT
RWT's Avatar
Drives: 2020 Camaro RS
I would open a case with GM Customer Assistance. With my Colorado when the shudder came back after the #18-NA-355 flush they replaced my TC.
RWT
2020 Camaro RS, V6, 6MT, Satin Steel
2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray
2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic
RWT is offline   Reply With Quote
Old 11-22-2019, 06:45 PM   #12
ScatPack
ScatPack's Avatar
No 12/12 means 12months, 12 thousand miles. Thats the warranty that comes with dealer repair work. If they repair your car under warranty of if you pay cash for the repair, they offer a 12 month 12k mile warranty on those repairs. They are obligated to redo the repair if it didnt fix the problem, or it broke again.
Old 12-05-2019, 12:00 AM   #13
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
When driving the A8 in manual mode there is never a need to downshift to 1st gear when slowing down. Downshift only to 2nd gear and let the car downshift to 1st when it's ready.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 12-05-2019, 02:47 PM   #14
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
ScatPack is correct. Techs are paid flat rate, so if there is a mistake they need to fix it with no pay for fixing it as they received pay for the first fix. It is their responsibility, but it does not make the dealer or the tech any additional compensation, so the "run around" is usually given.
Now, on the shudder issue and the fluid flushes. The symptom is from the stock converters poor design. The flush is only a bandaid intended to get you past the warranty period, and then it is no longer a liability to the auto maker. The shudder is from the fluid aerating and then it cannot provide the clamping pressure for the clutches and steels, and the metal HCI2000SS found is from the damaged caused by the shudder, and all will have this damage depending on how long the shudder was present. ONLY a good proper designed aftermarket converter can correct the cause. GM does not want the expense of replacing the torque converters so very few are able to get this under warranty, and it is just the same design they replace it with, again NOT addressing the cause, only the symptoms. There are a few proven brands that correct it all AND increase acceleration substantially, but if the symptoms have been present for any length of time, wear and damage very likely has already started.
Anyone that wants to source one of the proven aftermarket units, email our Engineering department directly: Tech@EliteEngineeringUSA.com
Hope this helps!
Elite Engineering is offline   Reply With Quote
18-na-355, a8 transmission, shudder, tsb
