Old 10-09-2019, 02:18 PM   #1
StraVltg
Drives: 2019 Chevy Camaro SS 1LE
Simple 100+ rwHP Increase on 2019 Camaro SS 1LE
National Speed in Richmond, VA, just completed a fairly simple upgrade on my 2019 Camaro SS 1LE that yielded a 100+ rwHP increase. Working with National Speed and Stainless Works my SS produced 461 rwHP on the dyno. The only other mod is a GM Performance CAI. The build is fairly simple and produced eye popping results. Details include:
  • Stainless Works long-tube headers - 2.00" primary diameter - 3.00" collector diameter - with high-flow catalytic converters
  • Stainless Works axle-back exhaust system - factory NPP exhaust - factory connect - 304 stainless steel construction - Chambered S-Tube mufflers with 4.00" diameter quad slash cut tips
  • DSX Flex Fuel kit
  • DEI Spark plug wire Protect-A-Boot sleeves
  • MSD spark plug wires - 50 ohms/ft - 8.50mm wires - spiral core conductor
  • Mishimoto 160 degree thermostat
  • HP Tuners
Shocking performance results. And the sound is absolutely sinister. I highly recommend National Speed and Stainless Works. Has anyone had similar results?
StraVltg is offline   Reply With Quote
Old 10-09-2019, 02:23 PM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Congrats on your first post and for the new found power. I'm sure your ride will run harder and better now.
Be prepared to get some grief from others about the reality of a 100 rwhp gain for just bolt on mods with E.
What was the base line dyno? Most stock LT1s produce about 400- 410 rwhp on a dynojet.
Enjoy the new sound and extra thrust!
476 rwhp/440 rwtq (sold)
Old 10-09-2019, 02:32 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
dyno sheets? i asked my tuner about the msd plugs and he said dont waste your money lol and why the 160 tstat?
Old 10-09-2019, 02:36 PM   #4
StraVltg
Thank you. I have all the dyno charts.
Baseline dyno:
357 rwHP @ 5800 rpm
Final dyno:
463 rwHP @ 5700 rpm
Old 10-09-2019, 03:14 PM   #5
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Congrats man! Enjoy that awesome car, and welcome.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 10-09-2019, 03:23 PM   #6
Burly
Burly's Avatar
Approximately how much did that cost?
Burly is offline   Reply With Quote
Old 10-09-2019, 03:25 PM   #7
StraVltg
Thank you! Gotta love it!
Old 10-09-2019, 03:26 PM   #8
kropscamaro16
not bad! a bunch of my cobalt ss buddies used to use national speed and seem like they do legit work ! why no intake ?
Old 10-09-2019, 03:27 PM   #9
StraVltg
$6K
Old 10-09-2019, 03:29 PM   #10
StraVltg
National Speed was an awesome experience. I have a GM Performance CAI.
Old 10-09-2019, 03:35 PM   #11
kropscamaro16
oh i just saw that sorry my bad!
Old 10-09-2019, 04:56 PM   #12
7speed
Drives: 21 SS
Seems like your hp was low from the GM intake already?
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 10-09-2019, 05:04 PM   #13
appleman22
Drives: 2017 1ss 1le
truth! the gm intake is hot garbage. I removed mine for the stock airbox, and felt an immediate rise in power and smoothness
appleman22 is offline   Reply With Quote
Old 10-09-2019, 05:06 PM   #14
Joker328
Drives: TBD
This. Pretty sure there are one or two threads about GM techs ****ing up the tune when installing the intake leading to significantly lower performance. Wonder if that is part of the reason for the large delta here.
Joker328 is offline   Reply With Quote
