![]() Drives: 2018 ZL1 coupe Join Date: Nov 2018
'18 ZL1 A10 - full throttle surging on track
Yesterday we ran our ZL1 at Wild Horse Pass East course in Phoenix, and I was experiencing full throttle surging/hesitation on the straights.
'18 ZL1 A10, ~11k miles Stock GY supercar 3 tires Mix of pump 91 and 100 unleaded, calculated ~94 octane. Ambient temps in the mid 90s When I first felt it, I was running PTM Sport 1, and I thought it might be the traction control/ stability control, but it was only happening at full throttle on the straights, so I thought that was unlikely. I ran the car in Sport 2 and Race, and it did it in every mode. The surging was present on straights after left and right turns, and the chicane (right/left). It was more apparent the harder the car was pushed... my wife didn't experience nearly to the extent I did, but she did tell me it was noticable even at her pace. I've never experienced this on the street, though the car has been run to ~140 a couple of times on a 'private, closed course'. The following video is a clip from one session where you can see/hear the surging/hesitation. It's subtle, but there at 00:16 in 3rd, 00:20 in 4th. It's really obvious at 00:32 in 3rd gear. You can see in the video that the TC icon is not coming on when it occurs. After researching here, I found the TSB for the wiring harness rubbing on the body, which has not been addressed as far as I know. A quick look shows no exposed wires, but it is clear the sheet metal is wearing into the plastic corrugated tubing around the harness. I also found the thread on the belt rubbing the wiring harness. That does not appear to be the problem. There is also a member here who is on his third fuel pump, with a similar issue, but he reports it also happens in the corners. Anyone experience this issue with their ZL1/ZLE?? Any ideas? ![]() I'll be taking it to the dealer tomorrow, but I'd like to be armed with as much info as possible. |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I suggest not racing in Sport 1. It's hard to tell, but the engine is cutting power on purpose. Some guys have had air in the intercooler loop and the engine pulls power on high-IAT. You can also pull the battery cable, but I wouldn't do that until after you take it in. You don't want to clear any codes.
Please report back with what you find out.
I can understand it pulling power for high IATs... it was hot out.
But I wouldn't expect it to cut in/out causing surging. |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
Good to know it's doing it after left and right corners for you, I've only have hard long right corners, so I don't know if mine would act up on left corners, but I assume it would.
I'd suggest trying to find a long hard corner, like a looping on or off ramp to a highway, to see if you can recreate the problem, that would give your dealership more info to work with. Unfortunately my dealership just kept saying it was a defective fuel pick up assembly/pump, I'm taking my car back in this week to see if they will actually do some detective work instead of just throwing new parts at my car, I'll keep you posted.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
Dropped it off at the dealer this morning.
They're going to do the wiring harness TSB, and see if any codes show up. |
Thanks for update, looking forward to hearing what they say
#7 |
Dealer is waiting for the part to complete the TSB, but no codes were set by the surging so they're clueless.
This is what I was afraid of... without codes or being able to duplicate the problem the dealer is essentially refusing to do anything. I'm looking into getting the car on a dyno in Phoenix with a good GM performance shop to see if we can duplicate the problem. Other than that, I'm not sure what to do. Anyone have a contact at GM customer service that isn't clueless about these cars? |
#8 | |
I had to take this approach until my car started throwing codes, but it only started throwing codes because I got the car to act up a lot more by repeating what caused it over and over again, also the less fuel it had in the tank the more it started to throw codes. When I was down to 1/8 tank it got so severe I thought I wrecked my car at one point, it basically went into some sort of limp mode and slowly died on the side of the road. That created a check engine light. The car finally restarted and I drove it straight to the dealership.
#9 | |
It also did it with a full tank... and never below 1/2 tank. I don't think my problem is the same as yours, though the fuel pump is still a possibility. Given that you're on your third, I'm not sure the fuel pump is your problem, either.... |
#10 |
Picking the car up later tonight. Dealer didn't do anything other than the wiring harness TSB.
"If we can't replicate it, and it doesn't throw a code, how can we do anything?" ![]() Service manager is on vacation. I'll be chatting with him next week. |
#11 |
A somewhat long shot, but if you can replicate the issue at will, how about logging it with HP Tuners (VCM Scanner) and asking your tuner to help diagnose it?
#12 | |
I'm looking into a couple of shops in Phoenix where we might be able to duplicate it on the dyno. Of course, that's a 100 mile drive, and I'll have to pay out of pocket and hope GM will reimburse. |
#13 |
I downloaded the Cosworth software to dig a little deeper into the PDR data. Throttle is showing 100% during the surging, so at least the computer is seeing full throttle input.
Temps all look pretty good considering the hot conditions. What I found interesting was the inconsistency of boost pressure from lap to lap... FYI, lap 4 is the lap the clip in the OP was taken from. ![]() Even with traffic and varying lap times, full throttle occurs in every lap, but boost pressure varies quite a bit. Has anyone looked at their data? Seeing something similar?
#14 |
I took a mechanic from my dealership for a test drive yesterday while he hooked up his computer to my car to measure my cars data, while I don’t have that data to display here, when I took him on a long hard corner he called out the drastic drop in fuel pressure about one second before my car started to bog, choke and lose power.
Since I am already on my 3rd fuel pickup assembly in less than one year, he is going to call GM and start doing some research and let me know what he finds, as soon as he has any info I’ll share it. To the OP, if the challenge I’m having with my car is different than yours, I’ll stop posting on this thread, up until now it is unclear to me if we are experiencing the same problem, your thoughts?
