![]() Drives: V6 Camaro Join Date: Dec 2012
Another Skip Shift thread
Sorry to throw this out there but I've done several searches and it's had to find which brand of skip shift eleminator will work with my 2019 2SS 1LE. I know I can run it harder, shift into 4th or third and then come back. I intend to run it through the winter and some times you need to shift at low RPM's and you don't want the delay of another shift throw. So if someone has the same car and has installed one that works let me know the brand. Thanks.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
This is the one I installed on my 2017 SS with no issues. The same one is listed for 2019, as I'd expect there were no changes between 2016 - 2020 SS M6's.
https://www.amazon.com/Muzzys-CAGS-S.../dp/B01AO328FW
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
The one vtirocv posted will work fine I have the same on my 2018. Ignore the "just mat it" crowd that was the best $12 I spent on my car sometimes you just can't rev the hell out of it. When you do install it and it seemed easy you likely installed it on the reverse lock out solenoid instead they are identical plugs. The one you want is on top of the transmission towards the rear a real pia to reach.
#4 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
The very first review says it doesn't fit a 2018 SS 1LE, about two reviews down you have a 2018 1SS owner stating he got a CEL, the next review is a 2015 Camaro owner stating he got a CEL and when he put it on an ohm meter it read no resistance. |
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I drive mine in the snow (with Sottozeros) and do well with the traction control and low rpms in 2nd. Occasionally, I need to blast out of my works lot exit that is uphill. Then I turn the traction control off and spin the wheels in 2nd. I never start in 1st on snow cover roads. Otherwise, my normal driving style is 1st to 3rd if I’m granny shifting.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
If you learn to drive a bit differently, you will never get gated.
If driving hard just shift normally by pulling straight back to second. Hard is simply defined as hard accel going about the 3,000 RPM cut off. If driving sedately, simply pull half way to second, flip to the right in the neutral gate, then pull back left and down. I've been gated only a few times driving with CAGS. Or you can spend the $12.
#7 | |
![]() Drives: 2016 2SS Convertible Join Date: Oct 2017
I recently installed a skip-shift eliminator on my 2019 Z06, no issues there either. I bought that one from Southern Car Parts.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
#8 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
This is the one I used on my 2018 ZL1 6M...
https://www.phastekperformance.com/2...ip-shift-2.htm It is a little more money than $12, but worth every penny...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#9 | |
Drives: Camaro Join Date: Apr 2017
#10 | |
![]() Drives: 2019 1SS M6 NPP Join Date: Jun 2019
#11 |
Drives: Fast if no one's looking Join Date: Aug 2019
CAGS (Computer Assisted Gear Selection) first debuted on the 1990 Corvette ZR1 6 speed. Frankly it’s a godsend because it enables engineers to design and sell a car that would otherwise suffer from the federal gas guzzler tax and still be easily, cheaply, undetectably defeated by the owner. I don’t know how that’s any more of a win-win-win for everyone.
It’s worth the $12 to not have to change your shifting style that you’ve done for 25+ years. |
#12 |
![]() Drives: 2018 2SS 1LE Join Date: May 2017
After a few days of ownership, I figured out how to work around the 1-4 lockout by going to 3rd. But for $17 bucks and a quick install, I figured why not make it work like every other manual I've driven for the past 30+ years and never have to think about it again.
I got mine from RPI, no issues though it's only been a few weeks. |
#13 |
![]() ![]() Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
they all work, just get one and install it. You won't regret it. Skip shift sucks
#14 |
![]() Drives: 2SS - Nightfall Grey 6m, npp, nav Join Date: May 2016
Best $20 bucks I've spent. The skip shift really annoys me when it kicks in. Hated it on my vette and just as annoying on the Camaro. Unfortunately its a little hard to plug in with the Camaro unless you have a lift. I was lucky to have my dealer install it at no charge. BTW my gas mileage improved with it installed.
