Old 10-05-2019, 11:38 AM   #1
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Acceptable / Normal Oil Consumption?
Quick question to those who keep track of their Oil levels.
Would you say that consumption of ~ 1 Quart per 2,850 Miles in the LT1 is acceptable / OK?
Thanks for your contributions.
Old 10-05-2019, 11:46 AM   #2
huiez
Drives: 2019 1SS M6 NPP
Personally I would not be happy with that. Mine has 3300 or so miles and I can't tell it has used any.
huiez is offline   Reply With Quote
Old 10-05-2019, 12:33 PM   #3
Eldi Z
Thanks for the input.
I am talking middle of the Hashmarks on the Dipstick, after it was at the full mark (2580 miles ago) at the top of the Hashmarks right after the oil change.
Old 10-05-2019, 02:19 PM   #4
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
1 qt. per 3000 miles is considered normal consumption.
More than that and they will have you do an oil study.
3.8TransAM is offline   Reply With Quote
Old 10-05-2019, 05:23 PM   #5
Eldi Z
Meaning that 1 qt. per 3000 miles is the highest upper limit before an engine is considered to be an "oil eater" ?
I was told that for DI engines, higher oil consumption is to be expected (compared to the non-DI engines, I.E. LS series)
Old 10-05-2019, 05:41 PM   #6
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
When I worked at a dealership the industry standard is one quart per thousand, sucks but thats the standard they abide by. One quart in 3K would not seem unreasonable, not great but I wouldn't be trading it in.
Warrior102 is offline   Reply With Quote
Old 10-05-2019, 06:03 PM   #7
Eldi Z
Good Info.
Another question that might further help in diagnosing if consumption is actually as I think it is:
Between the lowest and highest points within the Hashmarks region on the Dipstick, how much of actual oil quantity does it translate?
Old 10-05-2019, 06:45 PM   #8
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Hmm, idk. First oil change was just off the full mark, so maybe 1/4 qt at most. Currently still dead on the full mark since the last change.
Zaqwert6 is offline   Reply With Quote
Old 10-05-2019, 07:40 PM   #9
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
I have no idea what is considered ‘acceptable’ but I put around 30,000 miles on my 2016 SS and it never showed any noticeable oil consumption. I’m at 22,000 on my 2018 SS and it’s the same, never a need to add oil between changes.
Wyzz Kydd is offline   Reply With Quote
Old 10-05-2019, 08:58 PM   #10
1500 miles after the last oil change, no appreciable loss, level is still at the top of the hashmarks on the dipstick (and exactly 10 qts were used for the fill). In fact I never recall any significant oil consumption, and I've had a supercharger for over a year now.
Given many others have a similar experience, I think 1 qt per 3000 miles would be on the high side.
Old 10-06-2019, 08:38 AM   #11
Eldi Z
Can anyone comment on what is the actual oil quantity from the lowest part of the hashmarks to the highest point of the hashmarks on the dipstick?
This could help indicate how much oil is being consumed from full (Top of the hashmarks) I.E. immediately after the Oil change schedule, to the next measurement.
Old 10-06-2019, 09:44 AM   #12
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Typically on a car it’s a quart from bottom of hash marks to top
Old 10-06-2019, 10:12 AM   #13
s346k
s346k's Avatar
Drives: like an old lady
my car was consuming quite a bit of oil until i switched from m1 5w30 to 0w40. it was around 10k miles, as well. i was adding a qt of 5w30 every 3k miles. i have 4500 miles on this 0w40 and haven’t added any. judging by the dipstick, i won’t have to add any before i change the oil again. it appears that the consumption has almost completely stopped. not sure if because oil weight, mileage on motor, or both.
Old 10-06-2019, 02:01 PM   #14
Eldi Z
If this is indeed the case, then my assessment of oil consumption on my engine was probably a little exaggerated.
After 2,850 Miles, the oil was right in the middle of the Hashmarks.
I made certain that after the last oil change, (2,850 miles ago), the oil stood right at the top point on the Hashmarks.
If from min. to max. it is indeed 1 Quart, then it is fair to assume that from max.- to mid. area of the hashmarks, it would be ~ 0.7 of a Quart (since I guess that the reading within the hashmarks area is not exactly linear).
This would effectively mean that the consumption of my engine was more like ~ 22.5 oz per 2,850 Miles.
This does not seem like an abnormal consumption for a DI engine?
