Go Back   CAMARO6 > Marketplace > Members Classifieds > Wash/Wash/Detailing and Cosmetic Maintenance Parts
Old 10-04-2019, 09:05 AM   #1
2SSRedline
Drives: '18 Camaro SS Redline, '20 Bolt EV
Chemical Guys Foam Cannon
Chemical Guys EQP322 Big Mouth Foam Cannon.
Used a few times, works well.
I had the car ceramic coated, so this foam cannon isn't that effective now.
The foam just runs off
$35.00 including shipping. PayPal only.
2SSRedline is offline   Reply With Quote
Old 11-10-2019, 09:26 AM   #2
2SSRedline
bump
Old 09-03-2020, 04:49 PM   #3
Subperfect
Subperfect's Avatar
Drives: 16 Camaro
still available?
Subperfect is offline   Reply With Quote
Old 09-03-2020, 05:30 PM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Attachment 1006182
Isn't that kind of the point? The foam runs off carrying away the dirt with it...
Old 09-03-2020, 06:14 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
No ...idea is the foam is to DWELL i.e. stay on the surface for 3 to 5 minutes, so it loosens all the dirt , then be rinsed off…It’s special soap that‘s made to stick.
https://images.app.goo.gl/3kXp6qmYTvxjHi7r5
Also remember this unit is made to hook with an air compressor, it won’t work with the hose.
Old 09-03-2020, 06:48 PM   #6
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
Hi -Do you the soap as well?
Zl1+911 is offline   Reply With Quote
Old 10-02-2020, 12:44 AM   #7
LED Crazy
okcamaros.com
LED Crazy's Avatar
Drives: 2016 SS
I still use a foam cannon after my ceramic coating. Reduces scratches. You may need to change what soap you use. I had to change mine.
In Oklahoma? Have a Camaro?! Join OkCamaro's on facebook!
Blake
https://www.facebook.com/groups/okcamaros/
LED Crazy is offline   Reply With Quote
Old 11-16-2020, 02:42 PM   #8
zaimer
zaimer's Avatar
Drives: 23 ZL1 6speed
Are you nuts or being a troll? . There is no "special", nor is there a need for it. Also, I'm 99% certain that this unit attaches to the pressure washer gun (as do most others, including the one I use). Pressure from a garden hose will not produce the proper foam.
zaimer is offline   Reply With Quote
Old 11-16-2020, 02:43 PM   #9
zaimer
zaimer's Avatar
I completely agree. There is no reason to ditch a foam gun because of ceramic coating (which that is another topic in itself IMO ).
Old 08-16-2021, 05:03 PM   #10
Junior2377
Drives: 2016 2SS Convertible
Still available?
Junior2377 is offline   Reply With Quote
