Old 10-03-2019, 02:46 PM   #1
CharlieRomeo
Drives: 2020 White ZLE A10
AWE exhaust is kinda...crooked.
I’ve had an AWE Touring full cat-back with PLPs installed for about a month now and I just now have noticed that the left side exhaust exits are not even. I always back my car in to parking spots so I don’t really see the rear of my car a whole lot. I was at the dealer today and as I was looking at it sit in the service bay, the uneven alignment really stuck out. My OCD was making my eye twitch and everything looking at it. I have not banged on it or caused any type of impact to bend it in any way.
Anyone else have this problem? I absolutely love the exhaust but for spending almost $2k on this setup, I would at least expect stuff to be visually even.
CharlieRomeo is offline   Reply With Quote
Old 10-03-2019, 02:51 PM   #2
appleman22
Drives: 2017 1ss 1le
contact them for a replacement?
appleman22 is offline   Reply With Quote
Old 10-03-2019, 02:52 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The tips are all independently adjustable...so if they're crooked it should be an easy fix.
Old 10-03-2019, 02:56 PM   #4
CharlieRomeo
The first thing I did was try to adjust the tips. No matter what I tried to do, that inside exhaust exit has just enough of an angle to cause the uneven alignment.
Old 10-03-2019, 03:02 PM   #5
CharlieRomeo
The right side exhaust tips look perfect. It’s just the left side that is slightly uneven. I’ll reach out to AWE and see what they say.
Old 10-03-2019, 04:04 PM   #6
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Loosen this clamp and twist the whole muffler.
I came across this when we were testing the systems. Simple fix should take care of it. Just make sure the clamp is tightened to the recommended spec.
Thank you,
Ricardo
Sales@Phastek is offline   Reply With Quote
Old 10-03-2019, 04:07 PM   #7
CharlieRomeo
Thank you,
Ricardo
Okay. I will give that a try. Thank you.
Old 10-03-2019, 04:50 PM   #8
phillyspecial
Drives: 2018 ZLE
Thank you,
Ricardo
This. I had the same problem and this solved it.
phillyspecial is offline   Reply With Quote
Old 10-03-2019, 05:46 PM   #9
GT-ER
Drives: 2018 Camaro ZL1
Like mentioned, it's the muffler. Just rotate it a little.
GT-ER is offline   Reply With Quote
Old 10-03-2019, 06:22 PM   #10
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Not a bad idea while you're under there to re-torque all the band clamps, after a few heat cycles mine all were out of spec.
Warrior102 is offline   Reply With Quote
Old 10-03-2019, 07:14 PM   #11
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
I had the same issue and had to rotate the muffler at the joint, as well as massage the hanger a bit. Took a bit but in the end came out fine. Same drivers's side, too.
DFW_Muscle is offline   Reply With Quote
Old 10-04-2019, 09:14 AM   #12
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
Thank you,
Ricardo
BTW you can hide the bolts...that is what I did! Also you need to do a better job of cleaning your tips @ Charlie Romeo.
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
