Old 10-03-2019, 10:16 AM   #1
nelsont
Drives: 2018 2SS Hot Wheels Convertible
replacing GYF1runflats what ar you guys using fr a jack
Im changing out the Goodyear run flats for Michelin P4S.
Have bought a small compressor and plug kit for trunk.
Car has no Jack, what are you guys using in place of the factory scissor jack?
Thanks in advance for your help.
Tim
nelsont is offline   Reply With Quote
Old 10-04-2019, 12:15 PM   #2
RynoSS
RynoSS's Avatar
Drives: 2018 Camaro SS 1LE
I would suggest a can of Fix A Flat and using your compressor to refill the tire vs. trying to jack it up, removing the wheel, and plugging the tire on the side of the road. At least that would get you back home or to a safe location.
Chevrolet decided to install RunFlats in place of a jack and spare tire set. Most likely for reduced vehicle weight, I'm sure.
2018 Chevrolet Camaro SS 1LE - Hyper Blue Metallic
RynoSS is offline   Reply With Quote
Old 10-04-2019, 04:09 PM   #3
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Heads up. Fix a flat will ruin your tpms so plan on buying a new one if you use it.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 10-04-2019, 10:43 PM   #4
RynoSS
RynoSS's Avatar
That's a good point, though a lot of companies claim to be TPMS safe. However, that's probably the last thing you're thinking about if you're potentially stranded somewhere.
Old 10-04-2019, 11:28 PM   #5
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Even with GYRF I keep a small compressor and plugs on board. Not sure why you would need a jack.
FYI, fix a flat makes sensor safe products.
Zaqwert6 is offline   Reply With Quote
