Old 10-02-2019, 08:43 AM   #1
htxSS
Drives: 2019 Chevrolet Camaro 2SS
Another Whipple build thread
Anyone looking to go with a Whipple in a 2019 SS should know that a slight inside bumper fabrication will be required for the Whipple reservoir to fit properly.
J-Rods has had mine for 2 weeks and its almost dyno tune time!
htxSS is offline   Reply With Quote
Old 10-02-2019, 09:26 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Looking great! Did you do any other work at the same time (LT4 fueling, flex fuel sensor, etc)?
Old 10-02-2019, 09:28 AM   #3
streetyme
streetyme's Avatar
Drives: 2016 2SS nav mag ride npp a8
Congrats on your purchase.
2016 2SS A8 mag ride npp exhaust nav sunroof Rotofab CAI Borla Atak NPP Corsa X pipe BBS CHR Extreme Contactsport
2.9 Whipple Elite catch can Rotofab Juiced Motorsports installed by STG Motorsports JMS Fuel Maxx
tuned by Gregs Tuning Operation
Weld Laguna 17x10 18x5
2006 mustang gt Magnuson Livernois stage 2 heads stage 2 blower cams dynatech headers 4.10's Circle D convertor 533/511bs) (9.8lbs)
streetyme is offline   Reply With Quote
Old 10-02-2019, 09:57 AM   #4
htxSS
Nothing with the fuel system. I had Kooks 1 7/8 long tubes (Off road connection pipes) and the roto fab done with the Whipple. Oh and colder NGK plugs
I will be running the 3.625 pulley to keep it around 8lbs of boost, so running out of fuel shouldn't be a problem
Old 10-02-2019, 09:57 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Congrats, I love mine...smiles per gallon every time I drive it.
8psi will put you right at the fuel system limits. I would of just did the LT4 setup for room to grow.
Old 10-02-2019, 10:00 AM   #6
htxSS
There is also a Mighty Mouse catch can
Old 10-02-2019, 11:54 AM   #7
Joshinator99
Moderator
Uh, like King said, you have much less wiggle room on the stock LT1 fuel system than you think... Pushing that envelope is a sure way to buying forged pistons sooner than later...
Old 10-03-2019, 09:59 AM   #8
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
King,
So is it the in tank pump, High pressure fuel pump and the injectors that should be changed to the LT4 system? What about the cam?
Thanks.
Mike.
ssmofo is offline   Reply With Quote
Old 10-03-2019, 10:17 AM   #9
KingLT1
KingLT1's Avatar
Here is what I am running.
LT4 injectors
LPE big bore high side pump
ZL1 low side with JMS pump booster
on 8-9 psi I can run pretty much run full pump E85 but my injector pulse widths are right on edge of safe, high and low side fuel pressures are perfect. So I have been mixing to keep E content around E70 to take a little strain off my fuel system even though it's probably fine. That keeps my injectors around 5.7ms and I can run about 21 degrees of timing. E70 I can get all my timing. E60 commands a degree or 2 less.
If you run the LT4 high side pump instead of the LPE you more then likely will need to keep the E-content under E60. Then you will need meth to get the timing up over 20 degrees. Not that timing has to be there, it's just these engines like the timing but the high compression with boost limits that feat without using higher octane.
A cam will allow you to get upwards of 11-12psi on E60 with the LT4 pump, but that is going to put you in the power range where it's time to consider forged pistons. So for me the LPE pump made sense because I didn't want to run meth and I am not doing a cam without doing pistons and I am not ready to tear into the motor yet.
As you can see the fueling situation is kind of complicated on these engines. GM really needed to put dual fuel injection on the gen 5 stuff from the get go.
Old 10-03-2019, 10:34 AM   #10
Juiced1
Drives: 2012 2SS CAMARO 45th
Congrats on the Whipple. We've done a bunch of them now and they always impress.
Juiced1 is offline   Reply With Quote
Old 10-03-2019, 04:05 PM   #11
htxSS
Numbers came in At 580 hp and 630 tq
Old 10-03-2019, 04:39 PM   #12
htxSS
Old 10-03-2019, 08:50 PM   #13
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Congrats
TrekGTO is offline   Reply With Quote
Old 10-03-2019, 08:59 PM   #14
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Good numbers on a heartbreaker.
