![]() Drives: 2018 ZL1 1LE Join Date: May 2019
ZL1 1LE M6 Hot trans temp at track
Ive been tracking my ZLE for a few months now and done all the fluid exchanges except the transmission so far. Yesterday at the track as I was scrolling thru my temps and pressure gauges to check the status of the car, i noticed the Trans temp was pinned at 300 degrees. This was after a 30 min session. There was no odd feelings or hard shifts, everything felt great. Ambient temp was about 84 degrees and my engine oil temp was actually about 10 degrees lower than usual.
Im thinking a fluid change can help remedy this, as Im sure the thermal capacity of the old fluid is pretty much toast. Has anyone else run into this before? Also the oem fluid is GM part 88861800?
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! Last edited by Junkyardspecial; 09-25-2019 at 08:25 AM. |
![]() Drives: 2017 Red Hot ZL1 Join Date: May 2015
My temps stay around 230-240 in an A10 with those temps and I run it hard. I'd say something is off.
Who Needs to KNOW?
You may want to look int 2019 under belly scoops that dump air into rack / trans area.
![]() Drives: 2019 Camaro ZL1 Join Date: May 2019
Sensor perhaps? Something tells me you would feel it if the fluid was really over 300 degrees in there or something would break.
2019 Riverside Blue ZL1 M6, PDR
That was another thought. Fluid has at the most 10k miles on it and only 4 or 5 hours of track use. I dont see how it has failed so quickly, Car drives fine at "300" as it does on a cold start. Ill be getting under it today to check it out.
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
I would be looking at the temp sensor also, but given 10K miles and some track use, a fluid change is called for anyway, IMHO.
#7 |
![]() Drives: White 2015 Z/28 Join Date: Jul 2017
#8 |
Camaro pilot
Drives: 69 Camaro, 2014 ZL1 Join Date: Dec 2015
^^ LoL !
2014 ZL1 Camaro
1969 Camaro |
#9 |
Changed the fluid with fresh AC Delco and temps have dropped a good amount but still runs very hot. 260-275 range.
#10 |
![]() Drives: '19 ZL1 1LE Join Date: Feb 2019
This might be a long shot, but do exhausts usually have heat shielding around the area of the transmission?
I know you got an aftermarket exhaust, perhaps maybe heat shielding is missing which might be contributing to the higher temps the transmission is being subjected to? |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
#12 | |
#13 |
hard track day 20-30min session 90 degree ambient temps.
Everyday driving brings around 150 degrees
