Old 09-23-2019, 02:37 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
6 speed removal.
i have a lift but no tranny jack. how heavy is the tr6060. can it be remove with 2 people or will i need a jack
Old 09-23-2019, 02:44 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Jack makes it EASIER.. otherwise gravity always wins.
https://www.harborfreight.com/450-lb...ack-61232.html
Cheaper than ER visit copay
ing for grip.
http://www.motorsportsne.com/
Old 09-23-2019, 02:49 PM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
I will be grabbing one of these myself, makes life easier, I wouldn't recommend trying to hold your transmission yourself no matter how light, one wrong move and you'll hurt yourself or your pocket when trying to buy to fix that transmission.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 09-23-2019, 03:20 PM   #4
JCunningham
Drives: 2017 2SS M6
thats for doing it on the ground. i have a lift and 2 people. from a ford sight they said the tr6060 only weighs 120lbs.
Old 09-23-2019, 03:25 PM   #5
JCunningham
Drives: 2017 2SS M6
i do have a nice stainless steel table on rollers thats 3 1/2 feet high. i guess i could set that on the table. but the lift only lift the car 4 feet so not sure if it will fit.
Old 09-23-2019, 04:05 PM   #6
Choda
Drives: Turbo 6.2
taking them out by hand is easy. putting them back in is a pain.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 09-23-2019, 04:13 PM   #7
JCunningham
Drives: 2017 2SS M6
when i pulled my engine in my 5th gen i didnt pull the trans. i cut the heads off long bolts to line up the transmission. used the bolts like studs. i probably kept them.
Old 09-29-2019, 11:05 PM   #8
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
The trans is light enough to handle, but it is easier with a trans jack. The TR6060 is about 150# wet. Two people can ah for it without too much effort.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 09-30-2019, 01:23 AM   #9
JCunningham
Drives: 2017 2SS M6
thanks
Old 10-18-2019, 10:46 PM   #10
JCunningham
Drives: 2017 2SS M6
My uncle had a very heavy duty trans jack from a bus shop. Made in the 50s i think. A Manzel 7000F made in Buffalo NY.
Old 12-02-2019, 12:51 AM   #11
oldman
Drives: SS 6 speed of course
The shifter is the hardest part of the removal IMO.
Old 12-03-2019, 11:48 PM   #12
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
At 150lb or even 200lb I'm sure 2 of you could handle it, the area of consideration is the position of your bodies.
With the lift at 4' you'd be in a bent over position which will compromise your back and possibly your shoulders.
Be careful, and I'm sure you know all of this, but just one tweek of the back and the project stops for a while.
Might be safer to use a trans jack for support and unbolt even if the lift will need to be lowered.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 12-03-2019, 11:56 PM   #13
JCunningham
Drives: 2017 2SS M6
ya i got the jack posted above. its probably like a 2000lb trans jack from a bus barn.
Old 12-12-2019, 09:55 AM   #14
JCunningham
Drives: 2017 2SS M6
my jack was too tall we got it separated then couldn't lower it far enough to clear the fire wall. we had to pick it up off the jack, kick the heavy jack out of the way then twist the trany sidways to clear the headers. If you have headers remove your o2s. i damaged the wires on one.
