![]() Drives: 2019 Camaro SS Join Date: Sep 2019
New owner with a couple of questions
Just purchased my first Camaro since my 2002 SS. Love the car but have a couple of questions. It's an SS, automatic with leather interior, memory seats, etc...(2SS package???)
Is there a place to get a Window sticker/build sheet? I know the tires are run flats, but should there be anything in the lower trunk compartment? |
It is a 2SS and the empty spot in the trunk is for a small compressor and bottle of green slime to fix your run flat. Welcome aboard. And send your VIN number here and they will tell you about your car. socialmedia@gm.com
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
If you have the GY runflats on your SS then there isn't anything in that storage space. Technically GY does not support repairs to runflat tires so no compressor or slime. GY says that driving on a "flat" runflat tire damages the sidewall and the tire must be replaced. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
One thing I see missing in the trunk is the tow hook used to pull the car up on a rollback! I see the space for it is empty!
And if you look on the underside of the piece of plywood covering the trunk compartment there should be a sticker with all the options and codes on the car.
#7 |
That too!!
#8 |
Op, did you buy your Camaro used? That’s probably why some things are missing.
#9 |
Thanks for all the responses! I did purchase it with 4800 miles on it and it was the head salesman's driver so I know who to talk to about the missing items
#10 |
Old school tech
Drives: Ruby 1LE - 2024 2SS 1LE Join Date: Mar 2014
Apparently, that old RPO sticker is no more. Now we get these in the driver door jamb. Download a code scanner and you get the codes in .csv format
#11 |
![]() Drives: 2SS - Nightfall Grey 6m, npp, nav Join Date: May 2016
No tire inflator with the 2SS. Would be nice if they included it. Also should be a fuel funnel and a tow hook. Mine also had a bag with brake ducts to use when at the track.
#12 |
![]() Drives: 2019 Chevrolet Camaro 2 SS Join Date: Aug 2019
I just googled how to get the window sticker for my car using the VIN. I think they charged me $7. monroneylabels.com I believe it was.
