Old 09-21-2019, 04:34 PM   #1
ChillaxAttack
ChillaxAttack's Avatar
Drives: 2017 Camaro 2SS
Service Stabilitrak/Power Steering, Left turns only
Hey guys,
Looking for some opinions. I recently installed headers and after the install I get a service Stabilitrak message and a power steering message if in a tighter turn, but only turning left and, from what I can tell, some input on the throttle. I pulled DTCs and have found a loss of comm with the steering angle sensor and ABS. If anyone has seen this before, I'm wondering if you had to just reprogram the sensor or replace the whole thing? Thanks!
ChillaxAttack is offline   Reply With Quote
Old 10-26-2022, 07:18 PM   #2
2017Zl16spd
Drives: 2017 Camaro Zl1
DID YOU EVER FIGURE IT OUT DEALING WITH EXACTLY THE SAME PROBLEM ON MY ZL1
2017Zl16spd is offline   Reply With Quote
Old 10-26-2022, 08:18 PM   #3
ChillaxAttack
Yeah, I found a wiring harness was rubbing against the headers. Once the insulation burnt away the wiring was shorting on the header
Old 12-07-2022, 04:35 AM   #4
2017Zl16spd
Which wiring harness? Anyway you can show me? Im bummed i barley saw this
Old 12-07-2022, 10:13 AM   #5
ChillaxAttack
Unfortunately, I no longer have the vehicle so I can't show you, but it should be on the left side of vehicle.
When turning left the harness got pushed right toward the header until it made contact. Hope that helps
Old 12-07-2022, 10:38 AM   #6
2017Zl16spd
Thanks Alot Man Ill Try To Figure It Out
Old 12-08-2022, 02:12 AM   #7
2017Zl16spd
Is It Like On The Bottom Or The Top? What Did You Do To Fix It?
Old 12-08-2022, 02:39 AM   #8
Aaron07
Aaron07's Avatar
Drives: 2017 2SS F1FTY
The one I know that can be an issue is underneath the coolant tank. Do a search on here it's a common thing.
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
Aaron07 is offline   Reply With Quote
Old 12-11-2022, 01:50 AM   #9
Jeb114
Jeb114's Avatar
Drives: 2021 300
You guys buy perfectly great streetcar's.throw all these parts at the car and have a thorn in your side till you sell the car.
Jeb114 is offline   Reply With Quote
Old 12-14-2022, 11:47 PM   #10
2017Zl16spd
Figured It Out Thanks To Both Of Yall! It Was The One Under The Coolant Tank! I Just Couldnt See It. It Burned Up The Insulation And The Cables Were Visible But Not Damaged At All. Zipties And Tape 5$ Spent.
Old 12-15-2022, 06:38 AM   #11
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
I have seen a lot of issues with headers damaging wire harnesses on the forum.
Wyzz Kydd is offline   Reply With Quote
