Old 09-19-2019, 07:03 AM   #1
caSStro18
Drives: 2018 Camaro SS
Painted Engine Cover
Has anyone successfully painted their engine covers? I tried but the paint just peeled right off. I used a plastic adhesion promoter and the Duplicolor paint with a clear coat. However, it just simply peeled off. I was thinking about getting it done at a body shop but I wanted to save some money and do it myself.
caSStro18 is offline   Reply With Quote
Old 09-19-2019, 07:17 AM   #2
orange devil
Drives: 2019 SS 2019 mustang GT
I painted mine with primer made for plastic.. cleaned it good with paint prep .then primer ..a few days later wet sanded the primer with some 1500 then 2000..base coat then 4 coats of clear .
orange devil is offline   Reply With Quote
Old 09-19-2019, 08:05 AM   #3
caSStro18
That looks really nice! Does it hold up well with heat? Also, what type of paint did you use? The center cover...did you do that as well?
Old 09-19-2019, 08:50 AM   #4
orange devil
It holds up great ..no issues..I used OEM paint a company I use called paintscratch they can premix it for you or even put in an aerosol can ..the center cover is carbon fiber from a C7 Corvette that I modified.
Old 09-19-2019, 12:21 PM   #5
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
That's pretty bad ass Orange, I like the carbon fiber look.
ssmofo is offline   Reply With Quote
Old 09-19-2019, 01:30 PM   #6
orange devil
Thank you ...yeah the carbon fiber really stands out well with the crush orange..I recently change my hood as well to a new carbon fiber One..trying to keep everything gloss black, carbon fiber and orange.
Old 09-19-2019, 06:38 PM   #7
caSStro18
I think where I messed up on the last attempt was the prep. I’m not sure how to prep this material to hold paint. The last attempt I did about three coats of plastic adhesion promoter, then the base coat of summit white, and then 4 coats of clear. All the same brand which was Duplicolor. It just peeled off easily. It simply would not stick to the plastic. It’s almost like the covers are made of something that is not plastic.
So, what’s the best way to prep this cover material to hold the paint?
Old 09-19-2019, 07:09 PM   #8
orange devil
So did you not primer before the base coat?
Old 09-19-2019, 07:18 PM   #9
caSStro18
Well, I used the plastic adhesion promoter since it said it was basically a primer. Now I'm wondering if I should have just used a primer made for plastic like you said you did. What was the primer you used?
Old 09-19-2019, 07:24 PM   #10
orange devil
I recommend this
Old 09-19-2019, 07:29 PM   #11
caSStro18
I recommend this
Thank you! Where did you get it? Also, what should I do to clean the cover before the primer? Last time I just used isopropyl rubbing alcohol. There must be a better way though. Did you sand the surface a little first? I don't want to flatten the texture of the cover.
Old 09-19-2019, 09:05 PM   #12
orange devil
You could order online or go to any professional paint and body supply store and get it.no need to sand a surface. leave that alone just clean it like you did before with the alcohol.
Old 09-19-2019, 09:11 PM   #13
caSStro18
Thank you so much! I was really bummed the first time because it looked so good until I noticed it peeling in one spot. That primer is kind of pricey so I hope it comes out better. Hopefully that was the problem I was having before and the primer will solve it. I'll let you know if I have any further questions. Thank again!
Mark
Old 09-19-2019, 09:18 PM   #14
orange devil
No problem ..I would even help you paint it ..if you want ?
