![]() Drives: Camaro Join Date: Oct 2018
Warranty Work
I have question about mechanics/dealerships and warranty work.
This morning I had my car serviced for the ever so-popular Shudder PSB. I've been doing my research thanks to everyone here. I made my appointment online detailing exactly what I needed done 5 days ago. My car only has 7k miles on it and I wanted the fluid change asap to avoid any future mechanical issues with the transmission/torque converter. My exact online message was
So I arrive and the Service Rep is like...do you have an appointment? I said yes and he couldn't find me in the computer. I told him that I made an online appointment. Then he goes...oh..that's why ![]() Then he proceeds to ask me how can I help him? Mind you this is 7:30a and I have to get to work, everything should be on the computer. I told him that I my car needed the Transmission Flush that's detailed in the Bulletin. His response was...did we call you? ![]() ![]() He then...hesitating...takes my keys. Ugh!! I had the car less than 1 year and I have 2 free maintenance services visits...and I feel like the customer services is blah. Is it because they aren't getting paid as much for warranty work or what? Then when I go to pick it up, another service rep sarcastically goes, your "special fluid" was changed and everything is good to go. ![]() You would think the service reps had to go and get their hands dirty...they aren't even working on cars. |
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Does your paperwork note that the correct fluid and flush were done?
![]() ![]() Drives: 2017 Camaro 2SS - M6, NPP, MRC Join Date: Jan 2010
Were you actively experiencing the shudder?
If so did you previously take the car there for the dealership to diagnose themselves? If no to the first, and you just hit a certain mileage and showed up with a service bulletin and a word of mouth history of other A8s having problems, replacing the fluid way early without an obvious issue should not have been done under warranty by my understanding of the process. Like any other component, you can replace it as early and often as you want, but if it's working properly and you're doing it for preventive purposes, that's on you. If no to the second, that would at least explain their hesitation - you may have diagnosed the problem on your own, even correctly, but they're the ones who have to get GM to approve the warranty work which they've only got your opinion on the matter to base their warranty claim payment request on, instead of through their own practices. And I'm sure there are plenty of people out there trying to pull a fast one on GM with bogus warranty claims for dealerships to be wary. |
#5 | |
In my opinion, it's better to be preventative on this approach (from the customer standpoint) than to deal with the repairs down the line with changing torque converters and such. If this issue is so wide-spread/class action lawsuit and all, I think everyone on the list of affected cars needs to get their fluid ASAP with or without the shudder. Last edited by MrTee12; 09-19-2019 at 03:19 PM. |
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
It's not really you that they are frustrated with, it's the process involved with the manufacturer. As posted earlier, if it isn't having the issue and you want the fluid change done, in all rights, the dealership could've charged you for that. However, I imagine with all the bad press about the A8, GM is not as rigid on paying for the flush, or asking proof from the dealer that it was needed. IMHO the A8 transmission in the Camaro has probably sold more Mustangs and Challengers than anything else. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I can understand your concerns about your A8 auto but I have known several people that requested changing the fluid and the dealership wouldn’t do it because theirs weren’t having any shudder issues. They were thinking the same as you about preventing any problems but the dealership told them they wouldn’t do the service!
#8 |
Retired from Car mfrs....
Many tsb’s Are issued “for complaint only”....Meaning the customer has got to complain about it, and the service advisor can verify it by inspection that it’s a failed situation. The simple reason is the car manufacturers figure if a person isn’t complaining about it, it’s not a problem , so why expend the expense to fix something that’s not broken, (in the customers mind). Not saying it’s right or wrong, it’s just the way it is…A good example is a noise/rattle in the door or cabin.. The TSB will tell you how to fix it if you’re hearing it, but doesn’t want you go looking for it if the customer is not complaining.
A Recall is obvious, it means that every car should be fixed no matter whether it’s exhibiting the issue or not. On another note, if you do anything online and don’t get an answer back via email that you are confirmed, you don’t have an appointment. Most dealers use their business development center (Internet department) to track everything that has to do with computers, unfortunately that’s service appointments too. If you have a lousy BDC, it affects service too. Many of the younger generation thinks the email and text works at dealers, but it’s still slow going to get them online, Many staff still don’t look at that as a necessary part of the biz......
#9 |
![]() Drives: 2018 Camaro 2SS Redline Join Date: Mar 2019
I just dropped my car off last night for warranty work. Scheduled and explained online. Apparently everything stays online and the service dept has no idea.
Getting the 1-2 hard shift fixed, replacing the not dimming rear view mirror. Tech wasn't able to replicate the groan from the rear end. I said keep it and keep trying. LOL |
#10 | |
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) ![]() |
#11 | |
I don’t get why they would be resistant. Gm is paying them a retail labor rate for the warranty work, sounds to me like they just don’t want to do the paperwork… Maybe it’s time you go look for another dealer… Or a sit down with the general service manager |
#12 |
Thanks everyone for explaining the perspective from the Service Departments end...I didn't have full insightful before.
#13 | |
#14 | |
