Old 09-18-2019, 05:20 PM   #1
stevekin87
stevekin87's Avatar
Drives: 2016 Chevrolet Camaro 1SS
Can I drive with mods listed before getting a tune?
I am installing a MSD atomic airforce 103mm manifold along with a Nick Williams 103mm throttle body on my 2016 camaro 1SS. I already have a Roto Fab CAI installed and everything else is stock. Is it safe to drive my car before a tune?
stevekin87 is offline   Reply With Quote
Old 09-18-2019, 05:28 PM   #2
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
A single crank and short easy drive to the tuner, probably. Long term, no. You are increasing air flow to the engine (causing lean conditions). The ECU can cope with it with long term fuel trims using the O2 sensors in closed loop mode. It can't cope as well in open loop during hard driving and before the O2 sensors are warmed up from cold starts. Will it kill your engine immediately? Probably not. Will it increase wear and cause premature engine failure? Almost certainly.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 09-18-2019, 06:29 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i drove with longtubes intake and exhaust for a few months didnt hurt anything but the check engine light would come on every week or 2 for cat codes finally got a tune and they went away
Old 09-18-2019, 07:25 PM   #4
stevekin87
stevekin87's Avatar
How much different is that than having my mods though?
Old 09-18-2019, 07:26 PM   #5
stevekin87
stevekin87's Avatar
Thanks for the reply. Im in san diego and am driving to vegas next weekend which is about 4.5 hours one way. I would be driving conservatively vice hot rodding. Does that matter?
2016 1ss, drive safe, msd, throttle body, tune
