Old 09-17-2019, 12:27 PM   #1
IneedAZ
IneedAZ's Avatar
Weapon X vs Interchiller Chiller
I am still on the fence if worth the cost plus labor cost, and if i do pull the trigger, what is different between the two? I see some chose the Weapon X and some Interchiller. Curious to those that bought one, why did u go with the brand you did vs the other?
Old 09-17-2019, 12:39 PM   #2
DDFast
DDFast's Avatar
Drives: ZL1 1LE
in for this info
DDFast is offline   Reply With Quote
Old 09-17-2019, 12:44 PM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
We've done a Weapon X chiller kit and it was amazing. The product was very high quality and easy to install with everything being plug and play. No crazy wiring or line splicing was required. The kit works flawless and even on hot days the coolant temps get down to under 40 degrees keeping the intake temps under 100 without issue. On the dyno the car put down 5 repeated pulls all within 3-4HP of each other in under an hour. On an LT4 that is a miracle.
Juiced1 is offline   Reply With Quote
Old 09-17-2019, 12:56 PM   #4
IneedAZ
IneedAZ's Avatar
Thanks for your feedback. Hopefully some others will chime in. I saw your PM. Thank you!!
Old 09-18-2019, 04:02 PM   #5
IneedAZ
IneedAZ's Avatar
I know more than one person purchased one of these. Please post !
Old 09-19-2019, 02:36 PM   #6
parish8
Drives: 17 SS a8
I have an interchiller sitting here in a box. The reason I went interchiller is the heat exchanger looks to be way bigger. My thoughts are bigger exchanger = cooler fluid temps.
If anyone has a weapon x unit to measure it would be nice to get actual measurements of the 2 units.
Old 09-21-2019, 07:53 AM   #7
IneedAZ
IneedAZ's Avatar
Forgot to ask what you guys paid to have it installed.
Old 09-26-2019, 01:39 PM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
it looks like 3 kit are available.
Weapon X
Killer Chiller
and Dave or (Active interchiler)
Old 09-26-2019, 01:47 PM   #9
IneedAZ
IneedAZ's Avatar
Weapon X
Killer Chiller
Never heard of Killer Chiller. I have heard the Weapon X is plug and play, wonder if the others are too?
Old 09-28-2019, 09:49 PM   #10
jrs580
jrs580's Avatar
Drives: 2016 2ss
I have a killer chiller that is coming off my 16.the meth takes care of the temp for me. I'll sell the whole system to you. It's been on the car for about a year and works good. Maybe 3 or 4 hundred dollars?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 10-02-2019, 08:53 PM   #11
Goohead
Horsepower whisperer
Drives: Camaro
Was talking to Dave from Active chiller, he spent about 30 min on the phone to go over the entire process, he mentioned his website is not up to date but he has a plug and play system for the 6th gen camaro starting around 1300 for without hx bypass and 1400-1450 for with hx bypass with a competition mode to turn off the cabin a/c.
Going to pickup one of his kits for a customer’s car I am working on
From talking to Dave he was the inventor of the competition mode and some other innovative features and told me he helped the guy from FI Interchiller when they first started and been in the hvac business for over 30 yrs
Here are some pics
https://m.facebook.com/Interchiller
Goohead is offline   Reply With Quote
Old 10-03-2019, 05:42 AM   #12
IneedAZ
IneedAZ's Avatar
Here are some pics
Thanks for the post, I will have to check them out. Looks like they are only an hour away from me.
Old 10-03-2019, 12:36 PM   #13
Goohead
Drives: Camaro
Np, You can tell he isn’t trying to sell you, which is refreshing in this industry when everyone else is doing the opposite
Old 10-03-2019, 01:38 PM   #14
parish8
Drives: 17 SS a8
That looks like a nice kit. It appears to be the same size heat exchanger as the fi interchiller I have but with all pre made hoses.
