Old 09-17-2019, 06:37 AM   #1
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
E Force 2650
It seems that Edelbrock does not have pulleys in stock for the 2650 in 3.5 and 3.25 uppers. Have looked online without success.
Anyone have a line on someone who does?
gotswap is offline   Reply With Quote
Old 09-17-2019, 06:48 AM   #2
laynlo15
Drives: 2022 Lt1 A10
You might check with Griptec.
Old 09-17-2019, 07:25 AM   #3
gotswap
gotswap's Avatar
Didn't even think of them, they are out of stock as well.
Old 09-17-2019, 07:49 AM   #4
laynlo15
They have build both of my new pulleys.
Old 09-17-2019, 09:14 AM   #5
gotswap
gotswap's Avatar
found a 3.25, that should get me just a touch above stock boost @ sea level since I am @ 6000 ft altitude.
Old 09-20-2019, 07:27 AM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
It only takes a 1 week do you have the numbers if not I listed them on some of my builds.
Old 09-20-2019, 09:04 AM   #7
gotswap
gotswap's Avatar
Totally followed your build and part numbers, much appreciated!!
I ended up getting the 3.25 direct from them, will be here today.
Old 09-20-2019, 09:15 AM   #8
gotswap
gotswap's Avatar
Question on the below. Did you hit 13.5 on stock lower with the 3.25 upper?
2650 3.25 pulley 644/633 13.5 psi
Old 09-20-2019, 09:17 AM   #9
laynlo15
Glad you found one. Good luck on getting it tuned with the new pulley. We usually see
a couple lbs of boost lost at your elevation depending on your other mods. Let us know how it turns out.
Old 09-20-2019, 09:34 AM   #10
gotswap
gotswap's Avatar
Thanks, I am hoping to gain back what is lost and add 1-2lbs. I figure we lose about 2-3 psi up here
