Old 09-16-2019, 07:26 PM   #1
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Clicking noise from rear suspension / wheel area at low speed
Click noise when rolling from accelerating to decelerating like low to medium speed traffic like sub 30mph.
Pulled wheel off, didn't see anything that appeared loose, one of rear upper links will make clank noise if you rotate it and hit the frame bracket. Same on both sides.
I didn't get chance to check if perhaps axle nut was loose since largest socket I own is 32mm - may have to get camaro sized just in case. I'll chock wheels next time and try the 5G camaro axle clank test, but manual so harder to do.
Noise is click / clank like noise - like solid metal on metal sound.
Scheduled service visit just in case don't solve it before then.
ing for grip.
http://www.motorsportsne.com/
Old 09-16-2019, 09:12 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
put the wheel back on and check for play in the rear bearing assembly. The large nut is 36mm and I doubt it is loose as it is dimpled on one edge.
Old 09-23-2019, 03:21 PM   #3
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Noise is gone, appears axle nut was 1/4 turn loose per dealer. There was TSB for similar noise on 17's. Time to invest in 36mm axle socket.
ing for grip.
Old 09-23-2019, 03:52 PM   #4
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I had a Z06 that did this as well. If I remember right I put 110Lbs on each rear axle nut and it solved the problem
pauly1119 is offline   Reply With Quote
Old 09-26-2019, 07:55 PM   #5
NightfallG17
NightfallG17's Avatar
Drives: 2017 CAMARO ZL1
CLICKING
I also have noticed a clicking sound, but mine has been coming from my driver side front wheel area and it is only when I first pull off when turning right? Any of you guys experience the same?
2017 ZL1 M6 with 3400 miles so far. Non daily driver, Garage kept
NightfallG17 is offline   Reply With Quote
Old 09-26-2019, 09:13 PM   #6
NightfallG17
FOUND IT
Found this about page 7 in. Copy and paste into your browser if clicking the link doesn't work.
https://static.nhtsa.gov/odi/tsbs/20...82871-5448.pdf
