Old 09-16-2019, 08:11 AM   #1
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Hard redline settings?
So im pretty comfortable tuning but this gm torque management system is a bit over complicated. Ive had hptuners for over a year and have began to refocus attention on setting a hard redline. Ive tried changing the extreme resume and hysteresis. Ive set them for each gear and increased the tq request but all ive gotten is a more aggressive but still smooth and non-bouncing limiter. Does anyone know how to get a normal hard hitting limiter?
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 09-16-2019, 10:35 AM   #2
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Post on HPT
ssmofo is offline   Reply With Quote
Old 11-02-2019, 07:20 PM   #3
floridanick
Drives: Chevrolet Camaro 2SS
Originally Posted by ssmofo View Post
Post on HPT
awesome reply.....
floridanick is offline   Reply With Quote
Old 11-04-2019, 09:32 AM   #4
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Tried that first. Didnt yield much. But i figured it out
Old 11-04-2019, 10:29 AM   #5
ssmofo
ssmofo's Avatar
Share it I put heavy duty valve springs and a cam in, want to raise the RPM hard limit, share the knowledge.
Old 11-04-2019, 02:52 PM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Simple..
In HPT. Engine/Fuel/Cutoff,DFCO
Set extreme cut-off- 7000
In Gear- 7000 for all gears. I leave park, neutral, reverse set 6000.
EOT(engine oil tem)- 7000 above 41 degrees for all speed.
Extreme Resume 6990.
This is if you want a 7k rpm rev limit. If you want higher then change accordingly. I shoot for 2-300rpm above the shift points.
Old 11-11-2019, 07:48 PM   #7
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Simple..
Yea thats most of it but it was still soft when i first tried that, i had to increase torque requested as it nears the limit so that it didnt close the throttle as much
Old 11-12-2019, 09:52 AM   #8
KingLT1
KingLT1's Avatar
Yea if other areas of the tune are off then the ECU will close the throttle...My post was based on the fact that the torque limits and driver demand stuff was all correct prior.
