![]() Drives: 2020 Camaro ZL1 (Shock) 6MT Join Date: Sep 2019
Mismatched paint between doors/fenders and bumper covers *New Car*
Hello all! I just picked up my 2020 Shock ZL1 last weekend. I couldn’t be more impressed with the car (my first ever sports car), however I do have a couple questions that might put things into perspective. I’ve noticed a distinct separation of color hues between any steel pieces of the body, mainly the doors and fenders, and the bumper covers front and back. Is this typical for “shock yellow” or is this common on most colors? It’s almost as if the bumper pieces were painted at a completely different facility with a slightly different color. Or is this common on all late model Camaros? What is the standard by which the dealer would decide upon to take action on, or say it is an acceptable flaw? Will post pics as soon as I get some sunny weather.
![]() ![]() ![]() ![]() ![]() Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
I know that paint can look slightly different when the part is either metallic or plastic.
But there's no reason that it would not match that way. They normally apply a primer to avoid this issue. I'd bring it back to the dealer and raise the concern. My car doesn't have mismatch at all. Yours shouldn't.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
Wilf
Drives: Gen 6 HyperBlue SS, Yellow C7 Join Date: Jun 2014
It could be that it was damaged in shipment and bumpers redone by the dealer then claimed off GM/carrier. This is a relatively common occurrence.
It is not disclosed often but should be. Try taking a picture under different light sources, sun, incandescent and fluorescent. You will be surprised. I'm a yellow car fan and have lots of experience. The tint coats are the hardest to match. I've had a repair painted 4 times to get a match. It seems 2 is minimum and often they just want to blend it in so you can't notice the mismatch so easily. |
![]() Drives: Chevy Camaro Join Date: Jul 2019
This is normal between plastic and steel, i have seen the from all car companies, some colors are more noticeable than others. Don't trip.
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
There were lot's of color variation issues between bumpers and body with certain 5th gen colors also...As noted, it's more noticeable with some colors more than others.
#6 | |
#7 |
Thanks to all for your replies.
#8 |
![]() Drives: 2020 Satin Steel 2SS Coupe Join Date: Jan 2011
I have a 2020 with Satin Steel Gray Metallic paint and I've noticed something similar. The paint on my bumpers matches the rest, but it looks very uneven, kind of hazy. It almost looks like someone sprayed on some quick wax and didn't completely wipe it off. It might be that the metallic flakes didn't spray on evenly. The paint on the metal portions looks good and consistent.
I remember seeing somewhere that the plastic parts are painted separately from the rest of the car and installed later on the production line. That could explain the variation in your color and my uneven look. When I get some free time one day, I'm planning on taking it into the dealer to see if it could fall under the warranty as a manufacturer defect. You might check into the same if the color is that far off. Look above the headlamp. First photo is in the garage. Second is in the driveway. ![]()
#9 |
These are the photos of the mismatched paint. Also, notice the touch up paint on the top of the bolts on the driver side fender mounts? The most forward driver side mount was also clearly bent at some point during assembly. Is this typical of GM to just touch up parts that are especially noticeable? I'm going to bring the car in for a 500 mile oil change in the next week or so and I will point out these items to the service and body shop managers, just to see where the dealership stands. Is this being OCD and picky, or am I getting a poor product.... Thanks again for any input or advice.
#10 |
Sorry about the positioning of the images....I think I've figured that out now....
#11 |
Ok...
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
My car does not have any signs of mismatch between the hood/fenders/bumper, but blue may be easier to get right or less noticeable to subtle differences. If the pictures accurately depict how it looks in real life, I'd bring it in right away and see what the dealer can do. I wouldn't wait for the 500mi maintenance.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#13 |
![]() Drives: 2016 Silver Ice Metallic SS Join Date: May 2017
Yeah those colors are definitely off, the front bumper appears to be a shade darker than the fender and hood, like waaaaaay off in colors. I would definitely take it in and show them the pictures and show them in the light.
#14 |
That paint touch up is weird... I don't have that on my car. Looks like a damaged car where they have repositioned the fenders and did a touch up to hide the fact that the paint on top of this bolt has been chipped off.
Call the dealer for sure.
