Old 09-09-2019, 08:53 PM   #1
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Need to be educated on fuel system upgrades
Getting ready to have my Maggie 2300 TVS system installed. The tuner told me if I considered E85 I could see 35-50 rwhp. At first I was thinking $500 for LT4 injectors, $800 for LT4 HP pump, and $300 for a P&P E85 kit was a bit much for such little power but still thought about it. Car is my commuter and I have a C7 thats blown so not looking for a dyno queen. Truth is I dont want to mess with the fuel economy to bad. My question is this. Are the pump and injectors just plug and go with a tune? Do I need a Aux pump or anything else?
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 09-09-2019, 10:03 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You will need a low side for E85.
Old 09-10-2019, 02:51 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
If you are doing a blower even if you are not going on E, install the full OEM LT4 fuel system parts this way you are not running on the ragged edge of what the LT1 fuel system can support and won't break a piston.
Then if you want to run E later just add a flex fuel sensor kit from DSX our JMS fuel pump voltage booster and retune, We typically see 10% additional Rear Wheel Horsepower over 91 octane on E-85
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 09-10-2019, 04:44 PM   #4
tom's2005gto
Drives: 2016 2SS A8 Convertible
I know a guy...... ��
tom's2005gto is offline   Reply With Quote
Old 09-10-2019, 04:59 PM   #5
HyperBlueSS1le
HyperBlueSS1le's Avatar
Drives: 2018 SS 1le
Is the LT4 setup enough to run more than the standard 7 psi of boost most kits start out at?
*Procharger P1x w/ stage 2 IC and big red BOV* Full LT4 Fuel System* New Era Performance cat delete pipes* MM Wild catch can* AWE touring axel back exhaust *P3 multi gauge *ACS composite Zl1 side skirts * Zl1 1le painted flowtie
HyperBlueSS1le is offline   Reply With Quote
Old 09-10-2019, 05:21 PM   #6
KingLT1
KingLT1's Avatar
Of course it is. That's the entire point of upgrading to the LT4 fueling.
