Old 09-08-2019, 02:49 PM   #1
retmil
Drives: 2022 Wild Cherry SS
Jack Pads
Which jack pads does the Camaro community recommend for my '17SS coupe?
Thanks.
retmil is offline   Reply With Quote
Old 09-08-2019, 04:17 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Cheap: slotted hockey puck $10/2pk Amazon.
https://www.amazon.com/DEDC-Universa...gateway&sr=8-7
Not so cheap temporary/magnet: ZL1 Addons
https://zl1addons.com/collections/ja...-3-jack-magpad
Not so cheap semi-permanent: ZL1 Lift points (I use these)
https://zl1addons.com/collections/ja...-on-for-camaro
Old 09-08-2019, 04:20 PM   #3
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Thanks.
I use these:
https://www.amazon.com/Auto-Accessor...%2C181&sr=8-19
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 09-08-2019, 04:23 PM   #4
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Get the permanently mounted ones so they're always there in case you're on the road and it needs to be lifted. Buy two sets of these and sell the other two to another member, the car has six lift points. https://www.amazon.com/Dewhel-Billet...xpY2s9dHJ1ZQ==
Warrior102 is offline   Reply With Quote
Old 09-08-2019, 04:24 PM   #5
grampa_ss
grampa_ss's Avatar
Here's a cheaper version on the ZL1 add-on lift points.
https://www.amazon.com/gp/product/B0...3NQN9HFF&psc=1
Old 09-08-2019, 04:27 PM   #6
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Agreed.
I only have a set of four from ZL1 Addons, is anybody interest in selling me two lift points? Preferably red.
camaroJD is offline   Reply With Quote
Old 09-08-2019, 05:01 PM   #7
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
https://www.amazon.com/Dewhel-Billet...gateway&sr=8-1
these are what you want. I have them on my car and have used them for a couple years without issues. The ZL1 addons ones work too but they're more expensive and basically the same thing.
do NOT buy anything that doesn't bolt on to the pinch welds. Those can be unstable and can lead to damage to your pinch welds and/or rocker panels. NO pucks, NO magnets.
protovack is offline   Reply With Quote
Old 09-08-2019, 05:22 PM   #8
retmil
I appreciate all the help! I will go with the Dewhel pads.
Old 09-08-2019, 06:28 PM   #9
retmil
Are 6 pads really necessary or are folks using 4?
Old 09-08-2019, 06:47 PM   #10
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I just use 4
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 09-08-2019, 06:59 PM   #11
mrzab
Drives: 2018 Red Hot ZL-1
I have a set of the Dewhel pads in red I got for my ZL1-before I checked if it already had the pads... It did, so if you want these you may have have them.
mrzab is offline   Reply With Quote
Old 09-08-2019, 07:00 PM   #12
camaroJD
Necessary enough that I'm looking for two more. I really hate using the magnet/puck to jack up the car. It feels dangerous and unstable.
Old 09-08-2019, 07:01 PM   #13
HighIron
Drives: 2024 2SS Summit White
Dumb question:
I saw the amazon link, but other than the use of the plural "pads", actual number appears nowhere. Is it a set of 4 for $58.99?
HighIron is offline   Reply With Quote
Old 09-08-2019, 08:05 PM   #14
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Originally Posted by HighIron View Post
Dumb question:
1 set = 4 pads
Zaqwert6 is offline   Reply With Quote
