Old 09-07-2019, 10:28 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
zl1 or 1le rear caliper cross over line?
any one fix one befor? cant buy the part separate. id like to know what you did. probably just have to use universal and maybe use some 1/4 fuel like in the spot with the spacer in the middle of the line
Old 09-08-2019, 09:10 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You can find them on eBay once in a great while, about 25 bucks.
You could buy just a junk caliper and swap it over.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 09-08-2019, 09:29 AM   #3
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
https://www.racingbrake.com/Caliper-...VO-p/bm-42.htm
Probably other options out there too.
ing for grip.
http://www.motorsportsne.com/
Old 09-08-2019, 09:50 AM   #4
JCunningham
Drives: 2017 2SS M6
you sure thats the right one?
Old 09-08-2019, 03:01 PM   #5
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
You have to identify series for the brembo caliper.. then you cna narrow search. 17.. 42.. maybe be part of casting part No.
ing for grip.
Old 09-10-2019, 11:20 PM   #6
JCunningham
Drives: 2017 2SS M6
wrong one was too large.
Old 09-24-2019, 09:36 AM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Here's a Porsche line he wants 50 bucks though.
https://www.ebay.com/itm/Porsche-Bre...AAAOxy2O1SWFiW
Orange Krush II
Old 09-24-2019, 10:24 AM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
What about the other one listed... https://www.racingbrake.com/Caliper-...VO-p/bm-41.htm
ing for grip.
Old 09-24-2019, 10:35 AM   #9
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
or maybe....
https://www.zeckhausen.com/catalog/i...ath=24_213_649
Wonder if there stoptech caliper to brembo interchange somewhere ?
ing for grip.
Old 09-24-2019, 02:03 PM   #10
JCunningham
Drives: 2017 2SS M6
unavailable
i used a strait line from the parts store. $4, 5" i think fit perfect. it doesnt have the protector though.
Old 09-24-2019, 03:36 PM   #11
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Wilwood makes a bunch of different ones.. set for under $30 in most cases.
Example:
https://www.wilwood.com/hardware/Har...temno=190-3650
Doesn't appear protector protected anything
ing for grip.
Old 09-24-2019, 11:30 PM   #12
JCunningham
Drives: 2017 2SS M6
ya it didnt
Old 03-31-2020, 03:19 AM   #13
JCunningham
Drives: 2017 2SS M6
old but its a BC-42 caliper not BM-42. never found a line
Old 03-31-2020, 08:49 AM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
You would think there would be a rear of this as well....
https://www.summitracing.com/parts/ado-19121793
If someone is bored and wants to flip through the brembo catalog (called rigid pipe)...
www.brembo.com/en/Varie/2015-16 520BREMBO 520RACING 520CATALOGUE 520 528595 529.pdf
ing for grip.
