![]() Drives: 2016 Camaro RS Join Date: May 2016
Dome lights and Reverse lights
Anyone know what fuse controls the reverse lights and interior dome lights on V6 with RS? fuse box has a fuse that says (Reverse lights (no) ) and doesnt allow for a fuse to be put in. So is there another fuse specifically? That may also be for something else that controls these as well?
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
a.k.a map lights.... Both have stopped working.
![]() Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
Try BCM fuse 7. If not that take a look at BCM fuse 2
bcm 2 and bcm 7 look good. i guess i can just run through em all an check cont.
There is a fuse block on the side where the power feeds into the panel in the engine compartment. Someone had that strip apart and found that one of those fuse points blew. Requires replacing the entire strip. Not saying that's what it is but I would put a tester on the fuse to see if its getting power on both sides of the fuse. If its getting no power then that might be it. I would assume that other systems would be affected if that were the case.
crazy thing is, all fuses are good. also removed the gen5 homelink harness and connected back to factory... still no lights
#7 | |
![]() Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Edit: Got it figured out. Turns out it was the fuse for BCM 6.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: Last edited by EMTNLSS; 10-09-2020 at 06:30 AM. |
#8 |
2019 2SS
Drives: 2019 SS Join Date: Nov 2019
BCM 6 for me also. Anyone know what causes it to blow?
2019 2SS
Bored and stroked to 416ci Pro charger Stage 2 intercooler Crenshaw tune Custom ported and polished heads Kooks longtube headers Borla 3” cat back S-Type Biking 4 way adjustable coil overs Multiple BMR upgrades |
#9 |
2019 2SS
Anyone figure the reason out?
2019 2SS
