Old 09-01-2019, 01:47 PM   #1
GooseSS
Drives: 2018 Camaro SS
Coolant Leak - Bad T-Stat Housing
Hey all,
I had my 2018 SS in for service this week. I had noticed a couple of weeks ago, low coolant levels. I topped it off but knew it had to be going somewhere. I finally noticed that there was a pretty good leak, which ended up coming from a bad t-stat housing.
Has this happened to anyone else? I noticed at one point Mishimoto was developing a billet replacement (which got cancelled. Did they get banned from this forum??)
I also see that LMR has one they offer for an absurd amount of money.
I had the part replaced under warranty so this was not a big problem, but I wanted to start poking around and see what path you guys have gone down here.
Do most boosted guys run the OEM plastic t-stat housing?
Thanks all!
GooseSS is offline   Reply With Quote
Old 09-05-2019, 09:23 AM   #2
GooseSS
Bump.
Sent from my SM-G950U using Tapatalk
Old 09-05-2019, 01:18 PM   #3
Cechk01
Drives: 2016 Camaro 2SS M6
I had this issue on an 2005 mustang V6. For the V6 guys, the thermostat became a wear item, replacing it every 30k to 50k miles. They also had a guy that made metal ones, but the cost was so high that you could afford to replace the plastic one like 4 times before it made sense to get the metal one. Mine blew up right before i got home one day, but it was an easy fix.
sad to learn the LT1 engine is using a plastic thermostat housing too. :/
Cechk01 is offline   Reply With Quote
Old 09-16-2019, 11:19 PM   #4
GooseSS
Yeah, weird place to cheap out =\
