Old 08-31-2019, 10:41 PM   #1
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
WTB O2 Sensor Extensions
YoungFamous is offline   Reply With Quote
Old 08-31-2019, 11:53 PM   #2
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Dealership? I would not ever buy used sensors.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 09-01-2019, 02:59 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
fronts or rears? dont see why anyone would sell perfectly good o2 sensors unless the car was totaled.
Old 09-01-2019, 04:40 PM   #4
OneMadSS
OneMadSS's Avatar
Drives: 2011 Camaro SS
Exactly my thoughts. If you don’t wanna do dealership do to rockauto
OneMadSS is offline   Reply With Quote
Old 09-01-2019, 09:45 PM   #5
Richkidd87
Richkidd87's Avatar
Drives: 2016 Camaro 1SS Red Hot
eBay
Richkidd87 is offline   Reply With Quote
Old 09-01-2019, 11:42 PM   #6
JCunningham
Drives: 2017 2SS M6
rock auto is a good place
Old 09-18-2019, 09:06 AM   #7
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
guys. does anyone know the name of the Front 02 sensors? the ones that attach to the main cats. this is what i see but i dont know which one to get.
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 09-18-2019, 09:08 AM   #8
JeromeS13
Drives: 2017 1SS/1LE
Upstream is pre-cats. Downstream is post cats. If you click on the INFO tab, it even shows you diagrams of locations...
Also, what vehicle did you select? I'm seeing a very different list of part numbers for a 2017 SS Camaro....
Old 09-18-2019, 09:11 AM   #9
AlphaCamaro7
thank you so much. So i bought TSP headers and bought the Catted connection pipes. which means i need the Pre-Cats?
Old 09-18-2019, 09:58 AM   #10
JeromeS13
They're designed to work with your OEM sensors... Is there something wrong with yours?
Old 09-18-2019, 10:36 AM   #11
AlphaCamaro7
I threw them out lol now idk which ones to get cause I’m confused. Maybe a link or part number would help if it’s not too much trouble.
Old 09-19-2019, 07:46 AM   #12
JeromeS13
If you need all four, you need two upstream and two downstream. Pay attention, as some specify which side.
Old 09-19-2019, 05:49 PM   #13
YoungFamous
Amos6.2Jr
You would need some for long tubes though right?
Old 09-20-2019, 02:58 AM   #14
JeromeS13
No. Most headers are designed to work with the OEM sensors, and should include an extension harness for one or both sides in some cases.
o2 sensor, o2 sensors
