Old 08-30-2019, 01:17 PM   #1
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Do I need to consider any fuel upgrades with a 2300
Well the time has come as you can see in the other post. heres the bottom line. Car is my commuter. I dont want to kill the fuel economy. If I hit the 600rwhp mark and still around 18mpg Im fine. My C7 was cool with a SI Procharger. I switched up to a TI with long tubes and a new tune. Now I stare ar 14mpg on meth. I dont want to go back down that rabbit hole. I was thinking LT4 injects and a pump whether it be aftermarket or LT4 high side I believe
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 08-30-2019, 07:04 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I believe a Maggie 2300 with a mostly stock car will get you around 550 WHP. You wouldn’t need to upgrade the fuel system at that point, unless you want to run E85 of course... And if you start turning up the boost, then you’ll need to upgrade the fuel system. I figured it was just easier to do the LT4 fueling at the same time as the blower install and that sets the table for future pulley swap on my Whipple.
Old 08-31-2019, 09:04 AM   #3
Alpha6gen
Drives: 2016 A8 SS
My car has LTH and RF plus the 2300 dynoed 530/550 on 91 running the 1/4 11.1@ 126mph
Alpha6gen is offline   Reply With Quote
Old 08-31-2019, 02:24 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would, that way you can turn it up a little and have plenty of fuel. You don't want to push fuel limits on the stock pistons.
Old 08-31-2019, 03:46 PM   #5
teddyca
teddyca's Avatar
Thanks fellas. With that said wheres the best place to get the high side pump and injectors.
Old 08-31-2019, 03:49 PM   #6
Joshinator99
Moderator
I believe DSX Tuning had good numbers on the injectors and HPFP.
Old 08-31-2019, 05:14 PM   #7
Drsagacity
Drsagacity's Avatar
If you simply add the blower with the stock car it will be in the 550-575whp running 7psi. With that setup your mpg will be just like the stock car when you are cruising on the hey. Obviously if you get into boost you are gonna watch mpg drop.
No. You do not need to upgrade the fuel to run in that power range. If you want to run more than 7-8psi, you will need fuel. I think I posted details when I was going through my setup and I outlined the exact timing for fuel additions.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 08-31-2019, 10:45 PM   #8
Just one addition, I have this exact setup at 560 whp, and Ted suggested adding the voltage booster for guaranteed fueling stability near the top of the rev/hp range. I listened to him. The car has been flawless so far.
